I’d like to create a virtual lab using vmware fusion where installing Maas, Juju and some nodes. But after I’ve installed Maas 2.4 which type of power type I’ve to set o manage/deploy the future node.
What power did you use for fusion?
@riccardo-magrini, we’ve obviously upgraded MAAS and the OS several times since your original post. did you ever find a solution to your problem? have you tried upgrading to a later version of MAAS to see if you can make this work with later releases?
