We have the same problem (with 20TB drives) on 3.4 RC2. Here’s a script that will probably fix it (it’s been running for a few hours so far with good success but hasn’t completed yet - it can take ~2 days to run):
#!/usr/bin/env python3
# madblocks - Run badblocks on a disk with a very large block size support in read/write destructive mode.
# Author: Lee Trager <lee.trager@canonical.com>
# Newell Jensen <newell.jensen@canonical.com>
# Copyright (C) 2017 Canonical
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU Affero General Public License as
# published by the Free Software Foundation, either version 3 of the
# License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU Affero General Public License for more details.
# You should have received a copy of the GNU Affero General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
# name: badblocks-destructive-xxl
# title: Storage integrity
# description: Run badblocks on a disk in read/write destructive mode.
# script_type: test
# hardware_type: storage
# parallel: instance
# results:
# badblocks:
# title: Bad blocks
# description: The number of bad blocks found on the storage device.
# read_errors:
# title: Bad blocks read errors
# description: >
# The number of bad blocks read errors found on the storage device.
# write_errors:
# title: Bad blocks write errors
# description: >
# The number of bad blocks write errors found on the storage device.
# comparison_errors:
# title: Bad blocks comparison errors
# description: >
# The number of bad blocks comparison errors found on the storage device.
# parameters:
# storage: {type: storage}
# destructive: True
import argparse
import os
import re
from subprocess import check_output, PIPE, Popen, STDOUT
import sys
import yaml
# Give commands querying the system for info before running the test a
# short time out. These commands should finish nearly instantly, if they
# don't something is very wrong with the system.
TIMEOUT = 60
def get_storage_size(storage):
"""Return the size in bytes for the storage device."""
cmd = ["sudo", "-n", "blockdev", "--getsize64", storage]
print(
"INFO: Determining %s storage size by running `%s`"
% (storage, " ".join(cmd))
return int(check_output(cmd, timeout=TIMEOUT))
def get_block_size(storage):
"""Return the block size for the storage device."""
storage_size = get_storage_size(storage)
cmd = ["sudo", "-n", "blockdev", "--getbsz", storage]
print(
"INFO: Determining %s block size by running `%s`"
block_size = int(check_output(cmd, timeout=TIMEOUT))
while block_size * (2**32 - 1) < storage_size:
print(
"INFO: End block id exceeds 32bits with block size %d and storage size %d, Increasing block size to %s"
% (block_size, storage_size, block_size * 2)
block_size *= 2
return block_size
def get_meminfo_key(meminfo, key):
"""Get key values from /proc/meminfo."""
m = re.search(rf"{key}:\s+(?P<{key}>\d+)\s+kB", meminfo)
if m is None or key not in m.groupdict():
print("ERROR: Unable to find %s in /proc/meminfo" % key)
sys.exit(1)
try:
return int(m.group(key))
except Exception:
print("ERROR: Unable to convert %s into an int" % key)
sys.exit(1)
def get_parallel_blocks(block_size):
"""Return the number of blocks to be tested in parallel."""
print("INFO: Determining the amount of blocks to be tested in parallel")
with open("/proc/sys/vm/min_free_kbytes") as f:
min_free_kbytes = int(f.read())
with open("/proc/meminfo") as f:
meminfo = f.read()
memtotal = get_meminfo_key(meminfo, "MemTotal")
memfree = get_meminfo_key(meminfo, "MemFree")
# Make sure badblocks doesn't consume all memory. As a minimum reserve
# the min_Free_kbytes or the value of 0.77% of memory to ensure not to
# trigger the OOM killer.
reserve = int(memtotal * 0.0077)
if reserve < min_free_kbytes:
reserve = min_free_kbytes + 10240
# Get available memory in bytes
memavailable = (memfree - reserve) * 1024
# badblocks is launched in parallel by maas-run-remote-scripts so account
# for other storage devices being tested in parallel
output = check_output(
["lsblk", "--exclude", "1,2,7", "-d", "-P", "-o", "NAME,MODEL,SERIAL"]
output = output.decode("utf-8")
storage_devices = len(output.splitlines())
parallel_blocks = int(memavailable / block_size / storage_devices)
# Most systems will be able to test hundreds of thousands of blocks at once
# using the algorithm above. Don't get too carried away, limit to 128000.
return min(parallel_blocks, 128000)
def run_badblocks(storage, destructive=False):
"""Run badblocks against storage drive."""
blocksize = get_block_size(storage)
parallel_blocks = get_parallel_blocks(blocksize)
if destructive:
cmd = [
"sudo",
"-n",
"badblocks",
"-b",
str(blocksize),
"-c",
str(parallel_blocks),
"-v",
"-f",
"-s",
"-w",
storage,
else:
cmd = [
"sudo",
"-n",
"badblocks",
"-b",
str(blocksize),
"-c",
"-v",
"-f",
"-s",
"-n",
storage,
print("INFO: Running command: %s\n" % " ".join(cmd))
proc = Popen(cmd, stdout=PIPE, stderr=STDOUT)
stdout, _ = proc.communicate()
stdout = stdout.decode()
# Print stdout to the console.
print(stdout)
m = re.search(
r"^Pass completed, (?P<badblocks>\d+) bad blocks found. "
r"\((?P<read>\d+)\/(?P<write>\d+)\/(?P<comparison>\d+) errors\)$",
stdout,
re.M,
badblocks = int(m.group("badblocks"))
read_errors = int(m.group("read"))
write_errors = int(m.group("write"))
comparison_errors = int(m.group("comparison"))
if result_path is not None:
results = {
"results": {
"badblocks": badblocks,
"read_errors": read_errors,
"write_errors": write_errors,
"comparison_errors": comparison_errors,
with open(result_path, "w") as results_file:
# LP: #1733923 - Badblocks normally returns 0 no matter the result. If any
# errors are found fail the test.
if (
proc.returncode
+ badblocks
+ read_errors
+ write_errors
+ comparison_errors
) != 0:
print("FAILURE: Test FAILED!")
print("INFO: %s badblocks found" % badblocks)
print("INFO: %s read errors found" % read_errors)
print("INFO: %s write errors found" % write_errors)
print("INFO: %s comparison errors found" % comparison_errors)
return 1
else:
print("SUCCESS: Test PASSED!")
return 0
if __name__ == "__main__":
# Determine if badblocks should run destructively from the script name.
if "destructive" in sys.argv[0]:
destructive = True
else:
destructive = False
parser = argparse.ArgumentParser(description="Badblocks Hardware Testing.")
parser.add_argument(
"--storage",
dest="storage",
help="path to storage device you want to test. e.g. /dev/sda",
args = parser.parse_args()
sys.exit(run_badblocks(args.storage, destructive))
