Delete a region controller
maas $PROFILE region-controller delete [--help] [-d] [-k] system_id [data ...]
Positional arguments
- system_id
Deletes a region controller with the given system_id.
A region controller cannot be deleted if it hosts pod virtual machines. Use force to override this behavior. Forcing deletion will also remove hosted pods.
Keyword “force”
Optional Boolean. Tells MAAS to override disallowing deletion of region controllers that host pod virtual machines.
Command-line options
| Option | Effect |
Get system details
maas $PROFILE region-controller details [--help] [-d] [-k] system_id [data ...]
- system_id
Returns system details – for example, LLDP and lshw XML dumps.
Returns a {detail_type: xml, ...} map, where detail_type is something like “lldp” or “lshw”.
Note that this is returned as BSON and not JSON. This is for efficiency, but mainly because JSON can’t do binary content without applying additional encoding like base-64. The example output below is represented in ASCII using bsondump example.bson and is for demonstrative purposes.
| Option | Effect |
Get power parameters
maas $PROFILE region-controller power-parameters [--help] [-d] [-k] system_id [data ...]
- system_id
Gets power parameters for a given system_id, if any. For some types of power control this will include private information such as passwords and secret keys.
Note that this method is reserved for admin users and returns a 403 if the user is not one.
| Option | Effect |
Read a node
maas $PROFILE region-controller read [--help] [-d] [-k] system_id [data ...]
- system_id
Reads a node with the given system_id.
| Option | Effect |
Update a region controller
maas $PROFILE region-controller update [--help] [-d] [-k] system_id [data ...]
- system_id
Updates a region controller with the given system_id.
Keyword “description”
Optional String. The new description for this given region controller.
Keyword “power_type”
Optional String. The new power type for this region controller. If you use the default value, power_parameters will be set to the empty string. Available to admin users. See the Power types_ section for a list of the available power types.
Keyword “power_parameters_skip_check”
Optional String. Whether or not the new power parameters for this region controller should be checked against the expected power parameters for the region controller’s power type (‘true’ or ‘false’). The default is ‘false’.
Keyword “zone”
Optional String. Name of a valid physical zone in which to place this region controller.
| Option | Effect |
Read a node
- system_id
| Option | Effect |
Assign nodes to a zone
maas $PROFILE region-controllers set-zone [--help] [-d] [-k] [data ...]
Assigns a given node to a given zone.
Keyword “zone”
Required String. The zone name.
Keyword “nodes”
Required String. The node to add.
| Option | Effect |
