- Distribution: Ubuntu
- Distribution version: 22.04
- The output of “lxc info” or if that fails:
- Kernel version: 6.5.0-15-generic
- LXC version: “5.20”
- LXD version: “5.20”
- Storage backend in use: pool1 | dir | /mnt/pool1/
Steps to reproduce
- Step one : MAAS → Lxd → Add Lxd Machine → compose machine.
- Step two: Also MAAS gui → Lxd → myLxdHost → refresh host
From rackd.log
2024-02-09 06:33:53 provisioningserver.rpc.pods: [critical] Failed to discover VM host.
File "/usr/lib/python3.10/threading.py", line 1016, in _bootstrap_inner
self.run()
File "/usr/lib/python3.10/threading.py", line 953, in run
self._target(*self._args, **self._kwargs)
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/_threads/_threadworker.py", line 47, in work
task()
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/_threads/_team.py", line 182, in doWork
task()
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 244, in inContext
result = inContext.theWork() # type: ignore[attr-defined]
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 260, in <lambda>
inContext.theWork = lambda: context.call( # type: ignore[attr-defined]
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/python/context.py", line 117, in callWithContext
File "/snap/maas/32469/usr/lib/python3/dist-packages/twisted/python/context.py", line 82, in callWithContext
return func(*args, **kw)
File "/snap/maas/32469/lib/python3.10/site-packages/provisioningserver/utils/twisted.py", line 203, in wrapper
File "/snap/maas/32469/lib/python3.10/site-packages/provisioningserver/drivers/pod/lxd.py", line 295, in discover
discovered_pod = self._discover(client, pod_id, context)
File "/snap/maas/32469/lib/python3.10/site-packages/provisioningserver/drivers/pod/lxd.py", line 367, in _discover
storage_pools = client.storage_pools.all()
File "/snap/maas/32469/usr/lib/python3/dist-packages/pylxd/models/storage_pool.py", line 85, in all
response = client.api.storage_pools.get()
File "/snap/maas/32469/usr/lib/python3/dist-packages/pylxd/client.py", line 210, in get
self._assert_response(
File "/snap/maas/32469/usr/lib/python3/dist-packages/pylxd/client.py", line 162, in _assert_response
raise exceptions.LXDAPIException(response)
pylxd.exceptions.LXDAPIException: Certificate is restricted
