I have deployed a MAAS instance consisting of 1 x Region Controller and 2 x Rack Controllers.
I am trying to PXE boot a VM and provision it using MAAS.
There is an existing DHCP server in this network segment so MAAS DHCP is disabled.
The VM successfully gets an IP Address from the DHCP server but then it does not get a PXE offer.
There is another PXE Deployment server in this network segment however based on various posts, this has been set with a PXE Response Delay to allow MAAS to respond first. I have also tried setting the other PXE server to not respond to any clients. MAAS still doesn’t provide a PXE response.
Thanks for any help you can offer
