Hey folks!
I am having more PXE woes with a box that seems to throw up issues regardless of my efforts and compromises. Here’s the details:
ASUS Prime X470-Pro mobo with Nvme 512Gb boot drive. The onboard Ethernet is an Intel I211-AT. With CSM disabled in the BIOS I am able to enlist, commission and deploy up to the final reboot. At that point I see it post and PXE messages:
>>>Checking Media Presence......
>>>Media Present......
>>>Start PXE over IPv4 on MAC: FO-OO-BA-RR-BA-ZZ.
Downloading MBP file...
Booting local disk...
Failed to open \efi\boot\grubx64.efi - Not Found
Failed to load image \efi\boot\grubx64.efi: Not Found
start_image() returned not found
error: unknown error.
In the MAAS status for the node, it’s still deploying. The node does actually boot at that point but I see all the curtin actions related to posting events to MAAS failing, and deploy never gets marked as Deployed. This seems odd as presumably the files it’s trying to find should be coming from MAAS, or is this trying to load them from the boot drive? Perhaps there’s a problem with the PXE boot environment not having access to the Nvme? There’s an option in the BIOS for enabling an AMI driver for Nvme, which I’ve tried on/off with no discernable difference.
With CSM enabled, or set to auto, or set to ‘Legacy Only’ in various combinations (I can set UEFI first or legacy only for Net, Disk, USB etc boot individually) I get a different error, my old friend "Invalid MBR Magic, Treating as RAW", which presumably is because the drive gets formatted with GPT when partitioned for install, regardless of if it’s EFI or not. I also tried manually partitioning the drive with a /boot 500MB FAT partition followed by a 510GB ext4 root, that didn’t help.
I’ve stepped through the other threads related to PXE again and I’m pretty much stumped right now. I would welcome any advice onto directions of investigation to pursue next. I’ll be trying a different NIC in there today also.
EDIT: Some more info - MAAS is providing DHCP to the untagged subnet
