There seems to be a configuration issue with OptiPlex 7090 Small Form Factor which causes it to fail PXE boot with MAAS.
The boot gets stuck on (initramfs) with the following failures
ipconfig: BOOTIF: STOGIFINDEX: No such device
ipconfig: no devices to configure
The ethernet is working fine on the Ubuntu OS and I can see its MAC address and IP. I know that the server is working fine as we have other machines deployed on MAAS (i.e. OptiPlex 7050 Small Form Factor, Lenovo). The BIOS is also on the latest version.
Could there be something that I’m missing? Any help is appreciated.
Thank you for your suggestions. The models are slightly different.
on another machine(7050): Intel Corporation Ethernet Connection (5) I219-LM
7090: Intel Corporation Ethernet Connection (14) I219-LM (rev 11)
I could boot off USB and download Ubuntu fine without a problem, it’s only when I’m trying to boot off PXE to MAAS that it fails. It had also failed previously with Ubuntu 18.04, the same with Ubuntu 20.04.
