In a 2 rack controller setup with proxy support, a machine will be tied to the controller that help set it up initially.
On Ubuntu, the apt configuration will have the controller’s IP configured:
$ cat /etc/apt/apt.conf.d/90curtin-aptproxy
Acquire::http::Proxy "http://192.168.50.11:8000/";
If that controller goes down, you get errors:
apt update
Ign:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Ign:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Ign:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
Ign:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Err:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Could not connect to 192.168.50.11:8000 (192.168.50.11), connection timed out
Err:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
Unable to connect to 192.168.50.11:8000:
Err:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
Err:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Reading package lists... Done
Building dependency tree... Done
16 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy/InRelease Could not connect to 192.168.50.11:8000 (192.168.50.11), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy-updates/InRelease Unable to connect to 192.168.50.11:8000:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy-security/InRelease Unable to connect to 192.168.50.11:8000:
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/jammy-backports/InRelease Unable to connect to 192.168.50.11:8000:
W: Some index files failed to download. They have been ignored, or old ones used instead.
Would it be possible to configure MAAS to use a VIP or load balancer’s IP instead of the direct controller’s IP in this case?
