having to manually add the same proxmox configuration with the exception of a different vm id for each vm created in proxmox that uses maas, is getting really frustrating, has there been any thoughts about possibly doing templates? fx, a proxmox template for 1 proxmox host so all i would have to do is select the template in power management section, and set the vm id?
