I began by creating a VM in Proxmox and chose the “no media” option. On the first boot, since there was nothing bootable on the virtual hard drive, nor a “cd”, the VM defaulted to PXE boot where MAAS was able to commision it.
After commissioning, I deployed the VM through MAAS (after having configured the Proxmox power type) but discovered I made a slight mistake before deploying. No matter, I’ll just redeploy, I thought. However, now when I press “deploy” through the UI, MAAS powers on the VM just fine but the VM still defaults to booting into the hard drive instead of PXE booting. At the moment I have to manually PXE boot the VM through the Proxmox console whenever I want to re-commision/re-deploy a VM.
Is there anything I can do to make it so recommissioning/re-deploying a VM through the MAAS UI correctly makes the Proxmox VM PXE boot?
That’s all well and good, however that still requires manual action every time I want to re-commission/re-deploy a machine.
Optimally the VM should boot from its hard drive normally (for example a regular reboot should not make the VM PXE boot).
Then, if I want to re-deploy a machine I would optimally simply click the buttons in MAAS and have the machine switch to PXE boot.
In other words, I’d like to have MAAS control the boot order so I wouldn’t have to go into the Proxmox settings and change the boot order every time I want to re-deploy. I can do this with regular IPMI and ESXi power types.
