I’m not sure this is the right place to ask so I put this here and I’ll post the same request on the Juju Discourse.
I have a strange issue with latest MaaS release and/or openstack Charms (probably Masakari since this is the only one that interacts with MaaS)
here is the case : I deployed a working Openstack cluster with Masakari enabled
Before, when I was testing Masakari, I just initiated a “reboot” on a compute node and the node simply restarted
Now, when I do the same thing, the node is stuck shutoff (those are physical nodes with MaaS provider)
When I try to start them through MaaS (so through ipmi), the node starts then as soon as it try to start PXE, it simply shutdown itself, it’s not even initiating a DHCP/PXE request, simply shuting down before the bios ends its initialization phase
I tried to start those nodes many times through MaaS and it always do the same (nodes are Dell PowerEdge R630)
Only way to start those nodes is to start them from the idrac console
It might not be a “Charms” related issue since there was also new MaaS releases recently but since there are interaction between the Masakari charm and MaaS, I don’t really know where to route that issue
So any help gladly appreciated.
