Hello, i’m trying to download some files from maas node over http during deployment phase in pressed. Is there any variable usable in pressed where hostname or ip address of region node is stored?
I’m replying to my own question as I found the solution.
I used {{node.boot_cluster_ip}} to get hostname of a maas node in /etc/maas/preseeds/curtin_userdata file in late_commands section.
