Power management (CLI)
Configure a machine's power type
Choose a type in the dropdown menu that corresponds to the machine’s underlying machine’s BMC card.
Fill in the resulting form; the information required will depends on the power type.
The machine’s hostname – according to MAAS – is a randomly chosen string (here dear.ant). You should change this hostname to something descriptive, that helps you remember why this machine is in your MAAS network.
Which BMC drivers are supported
Tell me about BMC
BMC, or “Baseboard Management Controller,” is an extra microcontroller on the motherboard of a server which forms the interface between system-management software and the device’s hardware. The BMC can collect data from attached sensors, alert administrators to issues, and respond to remote-control commands to control system operation or power state, independent of the system’s CPU.
Cisco UCS Manager X X X
Digital Loggers, Inc. - PDU
Facebook's Wedge *
IPMI X X X X
Intel AMT X X X
Manual
OpenStack Nova X
Rack Scale Design X X X
SeaMicro 15000 X X X
Sentry Switch CDU - PDU
VMWare X X X
Virsh (virtual systems) X X X
