Concise Summary
When using terraform plan and the MaaS provider when TLS is enabled on the MaaS controllers, you will eventually run into
│ Error: Get "https://$REGION_CONTROLLER:5443/MAAS/api/2.0/machines/cacxen/": net/http: cannot rewind body after connection loss
This is fixed in https://github.com/juju/gomaasapi/commit/fee803278897a7853e3a41e3c04d3f6267a731f2, but the terraform provider hasn’t pulled in that dependency yet
Version and Build
MaaS:
# snap list maas
maas 3.3.0-13159-g.1c22f7beb 25850 3.3/stable canonical✓ -
terraform-maas-provider:
terraform-provider-maas $ git rev-parse HEAD
927857f308537f27fa42c49ab4eb0cfc9697206f
CLI, UI, or API?
API
How to reproduce
Enable TLS on your MaaS controller
Have a terraform file with data resources, the more the better.
Run terraform plan, during the state refresh and data reads, you’ll see some of them take more than a couple of seconds
module.maas-glue.maas_instance.fasrc_cluster_group["holy2a10303"]: Refreshing state... [id=4nymfg]
module.maas-glue.maas_instance.fasrc_cluster_group["holy2a10311"]: Refreshing state... [id=swa43k]
module.maas-glue.maas_instance.fasrc_cluster_group["holy2c02312"]: Refreshing state... [id=bb4axy]
module.maas-glue.maas_instance.fasrc_cluster_group["holy2c02311"]: Refreshing state... [id=eqd7mq]
module.maas-glue.data.maas_subnet.subnet_2476: Still reading... [10s elapsed]
module.maas-glue.maas_instance.fasrc_cluster_group["holy2c04308"]: Refreshing state... [id=t3nr8x]
Eventually there will be a failure:
Error: Get "https://$REGION_CONTROLLER:5443/MAAS/api/2.0/subnets/": net/http: cannot rewind body after connection loss
│ with module.maas-glue.data.maas_subnet.subnet_2476,
│ on ../modules/maas-glue/lookups.tf line 17, in data "maas_subnet" "subnet_2476":
│ 17: data "maas_subnet" "subnet_2476" {
│ Error: Get "https://$REGION_CONTROLLER:5443/MAAS/api/2.0/fabrics/0/vlans/": net/http: cannot rewind body after connection loss
│ with module.maas-glue.data.maas_vlan.vlan_2476,
│ on ../modules/maas-glue/lookups.tf line 34, in data "maas_vlan" "vlan_2476":
│ 34: data "maas_vlan" "vlan_2476" {
I don’t see any errors in the http log:
[root@holy-maas-region01 http]# pwd
/var/snap/maas/common/log/http
[root@holy-maas-region01 http]# grep subnets ./* | egrep '(02/15)|(15/Feb)' | tail -30
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:16 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:23 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:25 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:33 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:37 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:41 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:51 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:54 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:57:56 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:58:30 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:10:59:15 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:11:00:38 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:11:12:31 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:11:12:36 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:11:13:26 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.242.106.144 - - [15/Feb/2023:11:13:27 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.255.12.58 - - [15/Feb/2023:11:28:05 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.255.12.58 - - [15/Feb/2023:11:28:10 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.255.12.58 - - [15/Feb/2023:11:29:43 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
./access.log:10.255.12.58 - - [15/Feb/2023:11:29:44 -0500] "GET /MAAS/api/2.0/subnets/ HTTP/2.0" 200 6756 "-" "Go-http-client/2.0"
it seems like the Juju folks hit this and fixed it. It can be fixed in the terraform provider by bumping versions
