I’m repacking rocky 9 image for MAAS. It works perfectly when I use my own computer. On the server and in a virtual machine it fails due to the following setting -cpu host is unsupported
https://github.com/canonical/packer-maas/blob/main/rocky9/rocky9.pkr.hcl#L43
I wonder if one can run the build without this option. Simply removing this option causes kernel panic.
It seems kvm is enabled:
$ sudo kvm-ok
[sudo] password for afedotov:
INFO: /dev/kvm exists
KVM acceleration can be used
Here is the error message:
qemu-system-x86_64: CPU model 'host' requires KVM or HVF
r00ta
4
I don’t know by heart (if anybody knows, please jump in!).
Since you have a working machine, I’d first check and compare all the packages and their versions - qemu, packer and the others installed
thanks for your suggestion!
adding a user to kvm group helped on a server without VM, probably the script was modified to run as unprivileged
system
Closed
7
