Hi, I’m trying to set up the OpenstackNova Power Type on MAAS but I keep stuck in a “Power Error” status.
Openstack VM details
RC file
Power Configuration on MAAS
I can ping the VM (00-teste) from the controller.
Any thoughts on this?
RC file
The error message that shows up now is: “Unable to power off 00-teste: Power control software is missing from the rack controller ‘maas-controller.maas’. To proceed, install the python3-novaclient package”
I went to https://pypi.org/project/python-novaclient/ and installed pip and then
pip install python-novaclient
Rebooted the maas-controller but still shows the error message.
Hello @jbacelo,
I have the same error to configure power type in MAAS for openstack virtual machine for a project.
Do you have find something about this from February 2020 ?
I search a lot and i didn’t find something.
Best regards
This seems to be a missing dependency issue on snap-deployed maas environments. You can follow the bug report here: LP Bug
