Not able to add back SSD into MAAS storage
Hi All,
My server had 1*ssd and couple of hdd and it is shown under storage tab in MAAS.
I tried deleting the SSD storage from storage tab in MAAS. After that I only see HDD under the storage tab for the server.
Now how can I add back the SSD ? I tried deleting the machine from MAAS and starting from NEW state. Still I don’t see the SSD under storage tab anymore for this server.
you can insert the disk manually or recommission the machine
Thanks for the reply @r00ta
Since the SSD is in-built into server and MAAS is disabling the same in BIOS I tried enabling it and it just worked.
