I am trying to debug why some nodes are failing to commssion, PXE boot works, but Metadata fetch from maas is failing every time…
So trying to add tags to ad debugging serial console blows up with the CLI failing to accept it…
root@use1-maas-region-1:~# maas admin tags create name='debug_console' comment='debug serial console' kernel_opts="console=tty0 console=ttyS1,115200n8"
usage: maas [-h] COMMAND ...
optional arguments:
drill down:
COMMAND
login Log in to a remote API, and remember its description and credentials.
logout Log out of a remote API, purging any stored credentials.
list List remote APIs that have been logged-in to.
refresh Refresh the API descriptions of all profiles.
init Initialise MAAS in the specified run mode.
config View or change controller configuration.
status Status of controller services.
migrate Perform migrations on connected database.
apikey Used to manage a user's API keys. Shows existing keys unless --generate or --delete is
passed.
configauth Configure external authentication.
createadmin Create a MAAS administrator account.
changepassword
Change a MAAS user's password.
admin Interact with https://maas.<REDACTED>/MAAS/api/2.0/
http://maas.io/
'NoneType' object has no attribute 'endswith'
This feels like a python-twisted issue again…
I filed bug https://bugs.launchpad.net/maas/+bug/1931592 for this as this is a blocker for me.
