Delete script results
maas $PROFILE node-script-result delete [--help] [-d] [-k] system_id id [data ...]
Positional arguments
- system_id
- id
Delete script results from the given system_id with the given id.
“id” can either by the script set id, current-commissioning, current-testing, or current-installation.
Command-line options
| Option | Effect |
Download script results
maas $PROFILE node-script-result download [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Download a compressed tar containing all results from the given system_id with the given id.
Keyword “hardware_type”
Optional String. Only return scripts for the given hardware type. Can be node, cpu, memory, or storage. Defaults to all.
Keyword “filters”
Optional String. A comma seperated list to show only results that ran with a script name or tag.
Keyword “output”
Optional String. Can be either combined, stdout, stderr, or all. By default only the combined output is returned.
Keyword “filetype”
Optional String. Filetype to output, can be txt or tar.xz.
| Option | Effect |
Get specific script result
maas $PROFILE node-script-result read [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
View a set of test results for a given system_id and script id.
Keyword “include_output”
Optional. Include the base64 encoded output from the script if any value for include_output is given.
Keyword “filters”
Optional String. A comma seperated list to show only results that ran with a script name, tag, or id.
| Option | Effect |
Update specific script result
maas $PROFILE node-script-result update [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Update a set of test results for a given system_id and script id.
“id” can either be the script set id, current-commissioning, current-testing, or current-installation.
Keyword “filters”
Optional String. Include the base64 encoded output from the script if any value for include_output is given.
Keyword “suppressed”
Optional Boolean. Set whether or not this script result should be suppressed using ‘true’ or ‘false’.
| Option | Effect |
Return script results
maas $PROFILE node-script-results read [--help] [-d] [-k] system_id [data ...]
- system_id
Return a list of script results grouped by run for the given system_id.
Keyword “type”
Optional String. Only return scripts with the given type. This can be commissioning, testing, installion or release. Defaults to showing all.
Optional String. Include base64 encoded output from the script. Note that any value of include_output will include the encoded output from the script.
Keyword “filters”
Optional String. A comma seperated list to show only results with a script name or tag.
| Option | Effect |
