Return node devices
maas $PROFILE node-devices read [--help] [-d] [-k] system_id [data ...]
Positional arguments
- system_id
Return a list of devices attached to the node given by a system_id.
Keyword “bus”
Optional String. Only return devices attached to the specified bus. Can be PCIE or USB. Defaults to all.
Keyword “hardware_type”
Optional String. Only return scripts for the given hardware type. Can be node, cpu, memory, storage or gpu. Defaults to all.
Keyword “vendor_id”
Optional String. Only return devices which have the specified vendor id.
Keyword “product_id”
Optional String. Only return devices which have the specified product id.
Keyword “vendor_name”
Optional String. Only return devices which have the specified vendor_name.
Keyword “product_name”
Optional String. Only return devices which have the specified product_name.
Keyword “commissioning_driver”
Optional String. Only return devices which use the specified driver when commissioning.
Command-line options
| Option | Effect |
