Hi All,
I am using MAAS 3.3.4 and deploying my supermicro server with a SSD of 64GB (which is ideally used for OS) and a sda disk of 18TB with RAID 1 configured internally.
When I try to Deploy the OS on the server using MAAS and it ends up in reboot and never boots back as it is stuck in booting as shown below
Below are my installation logs in MAAS
curtin: Installation started. (22.1-0ubuntu1~22.04.1)
third party drivers not installed or necessary.
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: curtin command block-meta
get_path_to_storage_volume for volume sda({'id': 'sda', 'model': 'MR9361-8i', 'name': 'sda', 'serial': '600605b00b4a44e02d0247350606108f', 'type': 'disk', 'wipe': 'superblock'})
Processing serial 600605b00b4a44e02d0247350606108f via udev to 600605b00b4a44e02d0247350606108f
lookup_disks found: ['scsi-3600605b00b4a44e02d0247350606108f', 'wwn-0x600605b00b4a44e02d0247350606108f']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sda'] with allowed return codes [0] (capture=True)
/dev/sda is multipath device? False
/dev/sda is multipath device member? False
block.lookup_disk() returning path /dev/sda
Running command ['partprobe', '/dev/sda'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.068
devsync happy - path /dev/sda now exists
return volume path /dev/sda
get_path_to_storage_volume for volume sdb({'grub_device': True, 'id': 'sdb', 'model': 'SuperMicro SSD', 'name': 'sdb', 'ptable': 'gpt', 'serial': 'SMC0515D93621C3B5088', 'type': 'disk', 'wipe': 'superblock'})
Processing serial SMC0515D93621C3B5088 via udev to SMC0515D93621C3B5088
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088']
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sdb'] with allowed return codes [0] (capture=True)
/dev/sdb is multipath device? False
/dev/sdb is multipath device member? False
block.lookup_disk() returning path /dev/sdb
Running command ['partprobe', '/dev/sdb'] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.047
devsync happy - path /dev/sdb now exists
return volume path /dev/sdb
get_path_to_storage_volume for volume sdb-part1({'device': 'sdb', 'flag': 'bios_grub', 'id': 'sdb-part1', 'number': 1, 'offset': '4194304B', 'size': '1048576B', 'type': 'partition', 'wipe': 'zero'})
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088']
TIMED udevadm_settle(): 0.055
get_path_to_storage_volume for volume sdb-part2({'device': 'sdb', 'id': 'sdb-part2', 'name': 'sdb-part2', 'number': 2, 'size': '63342379008B', 'type': 'partition', 'uuid': '9bf1076e-567b-4c48-887c-82c5d169fb72', 'wipe': 'superblock'})
TIMED udevadm_settle(): 0.056
block-meta: extracted devices to clear: ['/dev/sda', '/dev/sdb']
Declared block devices: ['/dev/sda', '/dev/sdb']
clearing devices=['/dev/sda', '/dev/sdb']
start: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: removing previous storage devices
Running command ['mdadm', '--assemble', '--scan', '-v'] with allowed return codes [0, 1, 2] (capture=True)
mdadm assemble scan results:
mdadm: looking for devices for further assembly
mdadm: no recogniseable superblock on /dev/sdb
mdadm: no recogniseable superblock on /dev/sda
mdadm: no recogniseable superblock on /dev/loop3
mdadm: no recogniseable superblock on /dev/loop2
mdadm: no recogniseable superblock on /dev/loop1
mdadm: no recogniseable superblock on /dev/loop0
mdadm: No arrays found in config file or automatically
Running command ['mdadm', '--detail', '--scan', '-v'] with allowed return codes [0, 1] (capture=True)
mdadm detail scan after assemble:
TIMED udevadm_settle(): 0.020
Detected multipath support, reload maps
Running command ['multipath', '-r'] with allowed return codes [0] (capture=False)
Verifying /dev/mapper/mpath* files are symlinks
Running command ['dmsetup', 'ls', '-o', 'blkdevname'] with allowed return codes [0] (capture=True)
Running command ['pvscan', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
Running command ['vgscan', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
Running command ['vgchange', '--activate=y', '--config', 'devices{ filter = [ "a|/dev/mapper/mpath.*|", "a|/dev/mapper/dm_crypt-.*|", "r|.*|" ] }'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.019
Loading kernel module bcache via modprobe
Running command ['modprobe', '--use-blacklist', 'bcache'] with allowed return codes [0] (capture=False)
Generating device storage trees for path(s): ['/dev/sda', '/dev/sdb']
devname '/sys/class/block/sda' had holders: []
/dev/sda is multipath device partition? False
devname '/sys/class/block/sdb' had holders: []
/dev/sdb is multipath device partition? False
Current device storage tree:
sda
sdb
Shutdown Plan:
{'level': 0, 'device': '/sys/class/block/sda', 'dev_type': 'disk'}
{'level': 0, 'device': '/sys/class/block/sdb', 'dev_type': 'disk'}
shutdown running on holder type: 'disk' syspath: '/sys/class/block/sda'
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sda'] with allowed return codes [0] (capture=True)
get_blockdev_sector_size: info:
"sda": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "0",
"DISC-MAX": "0",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sda",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:0",
"MIN-IO": "262144",
"MODE": "brw-rw----",
"MODEL": "MR9361-8i",
"MOUNTPOINT": "",
"NAME": "sda",
"OPT-IO": "262144",
"OWNER": "root",
"PHY-SEC": "4096",
"RM": "0",
"RO": "0",
"ROTA": "1",
"RQ-SIZE": "256",
"SIZE": "17999671066624",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"device_path": "/dev/sda"
get_blockdev_sector_size: (log=512, phys=4096)
Running command ['fdasd', '--table', '/dev/sda'] with allowed return codes [0] (capture=False)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID'] with allowed return codes [0] (capture=True)
Checking if /dev/sda is a swap device
Found swap magic: b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
wiping superblock on /dev/sda
wiping /dev/sda attempt 1/4
wiping 1M on /dev/sda at offsets [0, -1048576]
successfully wiped device /dev/sda on attempt 1/4
shutdown running on holder type: 'disk' syspath: '/sys/class/block/sdb'
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sdb'] with allowed return codes [0] (capture=True)
"sdb": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "512",
"DISC-MAX": "2147450880",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sdb",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:16",
"MIN-IO": "512",
"MODEL": "SuperMicro SSD",
"MOUNTPOINT": "",
"NAME": "sdb",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "64",
"SIZE": "63350767616",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"device_path": "/dev/sdb"
get_blockdev_sector_size: (log=512, phys=512)
Running command ['fdasd', '--table', '/dev/sdb'] with allowed return codes [0] (capture=False)
Checking if /dev/sdb is a swap device
wiping superblock on /dev/sdb
wiping /dev/sdb attempt 1/4
wiping 1M on /dev/sdb at offsets [0, -1048576]
successfully wiped device /dev/sdb on attempt 1/4
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: SUCCESS: removing previous storage devices
blockmeta: detected storage config, using mode=custom
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: sda
TIMED udevadm_settle(): 0.043
devname '/dev/sda' had holders: []
Running command ['blkid', '-o', 'export', '/dev/sda'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="disk"', 'ENV{ID_WWN_WITH_EXTENSION}=="0x600605b00b4a44e02d0247350606108f"', 'ENV{ID_WWN}=="0x600605b00b4a44e0"', 'ENV{ID_SERIAL}=="3600605b00b4a44e02d0247350606108f"', 'ENV{ID_SERIAL_SHORT}=="600605b00b4a44e02d0247350606108f"', 'SYMLINK+="disk/by-dname/sda"\n']'
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_WWN_WITH_EXTENSION}=="0x600605b00b4a44e02d0247350606108f"', 'ENV{ID_WWN}=="0x600605b00b4a44e0"', 'ENV{ID_SERIAL}=="3600605b00b4a44e02d0247350606108f"', 'ENV{ID_SERIAL_SHORT}=="600605b00b4a44e02d0247350606108f"', 'SYMLINK+="disk/by-dname/sda-part%n"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: sda
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: sdb
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088']
TIMED udevadm_settle(): 0.051
labeling device: '/dev/sdb' with 'gpt' partition table
devname '/dev/sdb' had holders: []
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088']
TIMED udevadm_settle(): 0.060
Running command ['blkid', '-o', 'export', '/dev/sdb'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="disk"', 'ENV{ID_WWN_WITH_EXTENSION}=="0x515d93621c000088"', 'ENV{ID_WWN}=="0x515d93621c000088"', 'ENV{ID_SERIAL}=="SuperMicro_SSD_SMC0515D93621C3B5088"', 'ENV{ID_SERIAL_SHORT}=="SMC0515D93621C3B5088"', 'SYMLINK+="disk/by-dname/sdb"\n']'
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_WWN_WITH_EXTENSION}=="0x515d93621c000088"', 'ENV{ID_WWN}=="0x515d93621c000088"', 'ENV{ID_SERIAL}=="SuperMicro_SSD_SMC0515D93621C3B5088"', 'ENV{ID_SERIAL_SHORT}=="SMC0515D93621C3B5088"', 'SYMLINK+="disk/by-dname/sdb-part%n"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: sdb
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sdb-part1
TIMED udevadm_settle(): 0.063
"sdb": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "512",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sdb",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:16",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sdb",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "64",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
sdb logical_block_size_bytes: 512
adding partition 'sdb-part1' to disk 'sdb' (ptable: 'gpt')
partnum: 1 offset_sectors: 2048 length_sectors: 2047
Preparing partition location on disk /dev/sdb
Wiping 1M on /dev/sdb at offset 1048576
Running command ['sgdisk', '--new', '1:2048:4095', '--typecode=1:ef02', '/dev/sdb'] with allowed return codes [0] (capture=True)
Running command ['blockdev', '--rereadpt', '/dev/sdb'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.278
TIMED udevadm_settle(exists='/dev/sdb1'): 0.000
Wiping partition /dev/sdb1 mode=zero
/dev/sdb1 is 1048576 bytes. wiping with buflen=4194304
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1']
TIMED udevadm_settle(): 0.155
TIMED udevadm_settle(): 0.156
return volume path /dev/sdb1
Running command ['blkid', '-o', 'export', '/dev/sdb1'] with allowed return codes [0, 2] (capture=True)
No partition-specific dname
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sdb-part1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring partition: sdb-part2
TIMED udevadm_settle(): 0.152
"sdb": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "512",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sdb",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:16",
"MIN-IO": "512",
"MOUNTPOINT": "",
"NAME": "sdb",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "64",
"STATE": "running",
"TYPE": "disk",
"UUID": "",
"sdb1": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "512",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sdb1",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:17",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sdb1",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "64",
"SIZE": "1048576",
"STATE": "",
"TYPE": "part",
"UUID": "",
"device_path": "/dev/sdb1"
previous partition number for 'sdb-part2' found to be '1'
partition_kname=sdb1
calc_partition_info: sdb1 size_sectors=2048 start_sectors=2048
adding partition 'sdb-part2' to disk 'sdb' (ptable: 'gpt')
partnum: 2 offset_sectors: 4096 length_sectors: 123715583
Wiping 1M on /dev/sdb at offset 2097152
Running command ['sgdisk', '--new', '2:4096:123719679', '--typecode=2:8300', '/dev/sdb'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.300
TIMED udevadm_settle(exists='/dev/sdb2'): 0.000
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1']
TIMED udevadm_settle(): 0.171
TIMED udevadm_settle(): 0.167
return volume path /dev/sdb2
Running command ['blkid', '-o', 'export', '/dev/sdb2'] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule '['SUBSYSTEM=="block"', 'ACTION=="add|change"', 'ENV{DEVTYPE}=="partition"', 'ENV{ID_PART_ENTRY_UUID}=="18258040-a8e8-4960-861a-0c1e4253dd7a"', 'SYMLINK+="disk/by-dname/sdb-part2"\n']'
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring partition: sdb-part2
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring format: sdb-part2_format
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2']
TIMED udevadm_settle(): 0.163
mkfs /dev/sdb2 info: {'fstype': 'ext4', 'id': 'sdb-part2_format', 'label': 'root', 'type': 'format', 'uuid': '11dd6976-f787-429e-9214-696ec2b84447', 'volume': 'sdb-part2'}
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/sdb2'] with allowed return codes [0] (capture=True)
"sdb2": {
"ALIGNMENT": "0",
"DISC-ALN": "0",
"DISC-GRAN": "512",
"DISC-ZERO": "0",
"FSTYPE": "",
"GROUP": "disk",
"KNAME": "sdb2",
"LABEL": "",
"LOG-SEC": "512",
"MAJ:MIN": "8:18",
"MIN-IO": "512",
"MODEL": "",
"MOUNTPOINT": "",
"NAME": "sdb2",
"OPT-IO": "0",
"OWNER": "root",
"PHY-SEC": "512",
"RM": "0",
"RO": "0",
"ROTA": "0",
"RQ-SIZE": "64",
"SIZE": "63342379008",
"STATE": "",
"TYPE": "part",
"UUID": "",
"device_path": "/dev/sdb2"
Running command ['mkfs.ext4', '-F', '-L', 'root', '-U', '11dd6976-f787-429e-9214-696ec2b84447', '/dev/sdb2'] with allowed return codes [0] (capture=True)
Formated device type: partition
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring format: sdb-part2_format
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring mount: sdb-part2_mount
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1']
TIMED udevadm_settle(): 0.195
TIMED udevadm_settle(): 0.188
volume_path=/dev/sdb2 found slaves: ['sdb2']
kname_is_iscsi: no iscsi disk found for kname sdb2
Running command ['mount', '-t', 'ext4', '-o', 'defaults', '/dev/sdb2', '/tmp/tmp9alwn5nw/target/'] with allowed return codes [0] (capture=True)
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/sdb2'] with allowed return codes [0] (capture=True)
volspec: path=/dev/sdb2 type=part
info[DEVLINKS] = ['/dev/disk/by-partuuid/18258040-a8e8-4960-861a-0c1e4253dd7a', '/dev/disk/by-id/scsi-3515d93621c000088-part2', '/dev/disk/by-uuid/11dd6976-f787-429e-9214-696ec2b84447', '/dev/disk/by-label/root', '/dev/disk/by-id/scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', '/dev/disk/by-path/pci-0000:00:1f.2-ata-5-part2', '/dev/disk/by-path/pci-0000:00:1f.2-ata-5.0-part2', '/dev/disk/by-id/scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', '/dev/disk/by-id/scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', '/dev/disk/by-id/wwn-0x515d93621c000088-part2', '/dev/disk/by-id/ata-SuperMicro_SSD_SMC0515D93621C3B5088-part2']
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring mount: sdb-part2_mount
TIMED BLOCK_META: 10.239
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: curtin command block-meta
start: cmd-install/stage-network/builtin/cmd-net-meta: curtin command net-meta
net-meta mode is 'custom'. devices=[]
writing to file /tmp/tmp9alwn5nw/state/network_config with network config: network:
ethernets:
enp1s0f0:
addresses:
- 10.10.10.25/24
gateway4: 10.10.10.1
match:
macaddress: 0c:c4:7a:a4:4e:cc
mtu: 1500
nameservers:
addresses:
- 10.10.10.1
- 10.10.13.20
- 10.10.13.22
search:
- cto
- maas
set-name: enp1s0f0
enp1s0f1:
match:
macaddress: 0c:c4:7a:a4:4e:cd
mtu: 1500
optional: true
set-name: enp1s0f1
enp2s0f0:
match:
macaddress: 0c:c4:7a:a4:4e:ce
mtu: 1500
optional: true
set-name: enp2s0f0
enp2s0f1:
match:
macaddress: 0c:c4:7a:a4:4e:cf
mtu: 1500
optional: true
set-name: enp2s0f1
ens1np0:
match:
macaddress: 10:70:fd:f2:8a:82
mtu: 1500
set-name: ens1np0
version: 2
finish: cmd-install/stage-network/builtin/cmd-net-meta: SUCCESS: curtin command net-meta
start: cmd-install/stage-extract/builtin/cmd-extract: curtin command extract
Installing sources: [{'type': 'tgz', 'uri': 'cp:///media/root-ro'}] to target at /tmp/tmp9alwn5nw/target
start: cmd-install/stage-extract/builtin/cmd-extract: acquiring and extracting image from cp:///media/root-ro
Running command ['sh', '-c', 'mkdir -p "$2" && cd "$2" && rsync -aXHAS --one-file-system "$1/" .', '--', '/media/root-ro', '/tmp/tmp9alwn5nw/target'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: acquiring and extracting image from cp:///media/root-ro
Applying write_files from config.
finish: cmd-install/stage-extract/builtin/cmd-extract: SUCCESS: curtin command extract
start: cmd-install/stage-curthooks/builtin/cmd-curthooks: curtin command curthooks
Running curtin builtin curthooks
Configuring target system for distro: ubuntu osfamily: debian
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: configuring apt configuring apt
Transferred {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://10.10.10.1:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=K2ZRy6u9xjb5fzCmqe&oauth_token_key=6erQwWVDfsKBKqGuz2&oauth_token_secret=xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: K2ZRy6u9xjb5fzCmqe\\n endpoint: http://10.10.10.1:5248/MAAS/metadata/status/6x8gm6\\n token_key: 6erQwWVDfsKBKqGuz2\\n token_secret: xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\\n type: webhook\\n\n'} into new format: {'preserve_sources_list': False, 'proxy': 'http://10.10.10.1:8000/', 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports universe main restricted multiverse\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://10.10.10.1:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=K2ZRy6u9xjb5fzCmqe&oauth_token_key=6erQwWVDfsKBKqGuz2&oauth_token_secret=xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: K2ZRy6u9xjb5fzCmqe\\n endpoint: http://10.10.10.1:5248/MAAS/metadata/status/6x8gm6\\n token_key: 6erQwWVDfsKBKqGuz2\\n token_secret: xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\\n type: webhook\\n\n'}}
curthooks handling apt to target /tmp/tmp9alwn5nw/target with config {'preserve_sources_list': False, 'proxy': 'http://10.10.10.1:8000/', 'sources_list': 'deb http://archive.ubuntu.com/ubuntu $RELEASE universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-updates universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-updates universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-security universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-security universe main restricted multiverse\ndeb http://archive.ubuntu.com/ubuntu $RELEASE-backports universe main restricted multiverse\n# deb-src http://archive.ubuntu.com/ubuntu $RELEASE-backports universe main restricted multiverse\n', 'debconf_selections': {'grub2': 'grub2 grub2/update_nvram boolean false', 'maas': 'cloud-init cloud-init/datasources multiselect MAAS\ncloud-init cloud-init/maas-metadata-url string http://10.10.10.1:5248/MAAS/metadata/\ncloud-init cloud-init/maas-metadata-credentials string oauth_consumer_key=K2ZRy6u9xjb5fzCmqe&oauth_token_key=6erQwWVDfsKBKqGuz2&oauth_token_secret=xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\ncloud-init cloud-init/local-cloud-config string manage_etc_hosts: true\\nmanual_cache_clean: true\\nreporting:\\n maas:\\n consumer_key: K2ZRy6u9xjb5fzCmqe\\n endpoint: http://10.10.10.1:5248/MAAS/metadata/status/6x8gm6\\n token_key: 6erQwWVDfsKBKqGuz2\\n token_secret: xSH46fugb8ELMPnxWMxYu8aKC9SFHVD3\\n type: webhook\\n\n'}}
Running command ['unshare', '--help'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'lsb_release', '--all'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
got primary mirror: None
got security mirror: None
Apt Mirror info: {'PRIMARY': 'http://archive.ubuntu.com/ubuntu/', 'SECURITY': 'http://security.ubuntu.com/ubuntu/', 'MIRROR': 'http://archive.ubuntu.com/ubuntu/'}
Applying debconf selections
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'debconf-set-selections'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-query', '--list'] with allowed return codes [0] (capture=True)
unconfiguring cloud-init
cleaning cloud-init config from: ['/tmp/tmp9alwn5nw/target/etc/cloud/cloud.cfg.d/90_dpkg.cfg']
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-reconfigure', '--frontend=noninteractive', 'cloud-init'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-query', '--show', '--showformat', '${Version}', 'cloud-init'] with allowed return codes [0] (capture=True)
Set preserve_sources_list to True in /etc/cloud/cloud.cfg.d/curtin-preserve-sources.cfg with: {'apt': {'preserve_sources_list': True}}
write apt proxy info to /tmp/tmp9alwn5nw/target/etc/apt/apt.conf.d/90curtin-aptproxy
renaming /tmp/tmp9alwn5nw/target/etc/overlayroot.local.conf to /tmp/tmp9alwn5nw/target/etc/overlayroot.local.conf.old
Running command ['mount', '--bind', '/dev', '/tmp/tmp9alwn5nw/target/dev'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/proc', '/tmp/tmp9alwn5nw/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/run', '/tmp/tmp9alwn5nw/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--bind', '/sys', '/tmp/tmp9alwn5nw/target/sys'] with allowed return codes [0] (capture=False)
Diverting original update-initramfs in target.
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-divert', '--add', '--rename', '--divert', '/usr/sbin/update-initramfs.curtin-disabled', '/usr/sbin/update-initramfs'] with allowed return codes [0] (capture=False)
Adding 'local diversion of /usr/sbin/update-initramfs to /usr/sbin/update-initramfs.curtin-disabled'
TIMED subp(['udevadm', 'settle']): 0.017
Running command ['mount', '--make-private', '/tmp/tmp9alwn5nw/target/sys'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp9alwn5nw/target/sys'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp9alwn5nw/target/run'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp9alwn5nw/target/run'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp9alwn5nw/target/proc'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp9alwn5nw/target/proc'] with allowed return codes [0] (capture=False)
Running command ['mount', '--make-private', '/tmp/tmp9alwn5nw/target/dev'] with allowed return codes [0] (capture=False)
Running command ['umount', '/tmp/tmp9alwn5nw/target/dev'] with allowed return codes [0] (capture=False)
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-apt-config: SUCCESS: configuring apt configuring apt
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: installing missing packages
Curtin config dependencies requires additional packages: ['e2fsprogs']
Skipping install of {'ifenslave', 'vlan', 'bridge-utils'}. Not needed on netplan system.
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: SUCCESS: installing missing packages
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: configuring iscsi service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: SUCCESS: configuring iscsi service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: configuring raid (mdadm) service
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: SUCCESS: configuring raid (mdadm) service
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: installing kernel
Running command ['dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', '--option=Dir::Etc::sourcelist=/tmp/tmp8nw4thxf/sources.list', '--option=Dir::Etc::sourceparts=/tmp/tmp8nw4thxf/sources.list.d', 'update'] with allowed return codes [0] (capture=False)
Running in chroot, ignoring command 'start'
Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages [14.1 MB]
Get:6 http://archive.ubuntu.com/ubuntu jammy/universe amd64 c-n-f Metadata [286 kB]
Get:7 http://archive.ubuntu.com/ubuntu jammy/multiverse amd64 Packages [217 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy/multiverse amd64 c-n-f Metadata [8372 B]
Get:9 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [1017 kB]
Get:10 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 c-n-f Metadata [22.1 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1223 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [1199 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages [41.6 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 c-n-f Metadata [472 B]
Get:15 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [811 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 c-n-f Metadata [16.8 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages [1012 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 c-n-f Metadata [11.4 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages [1179 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy-security/restricted amd64 c-n-f Metadata [520 B]
Get:21 http://archive.ubuntu.com/ubuntu jammy-security/multiverse amd64 Packages [36.5 kB]
Get:22 http://archive.ubuntu.com/ubuntu jammy-security/multiverse amd64 c-n-f Metadata [260 B]
Get:23 http://archive.ubuntu.com/ubuntu jammy-backports/universe amd64 Packages [27.8 kB]
Get:24 http://archive.ubuntu.com/ubuntu jammy-backports/universe amd64 c-n-f Metadata [644 B]
Get:25 http://archive.ubuntu.com/ubuntu jammy-backports/main amd64 Packages [64.2 kB]
Get:26 http://archive.ubuntu.com/ubuntu jammy-backports/main amd64 c-n-f Metadata [388 B]
Get:27 http://archive.ubuntu.com/ubuntu jammy-backports/restricted amd64 c-n-f Metadata [116 B]
Get:28 http://archive.ubuntu.com/ubuntu jammy-backports/multiverse amd64 c-n-f Metadata [116 B]
Fetched 21.6 MB in 8s (2842 kB/s)
Reading package lists...
TIMED subp(['udevadm', 'settle']): 0.010
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'eatmydata', 'apt-get', '--quiet', '--assume-yes', '--option=Dpkg::options::=--force-unsafe-io', '--option=Dpkg::Options::=--force-confold', 'install', 'linux-generic'] with allowed return codes [0] (capture=False)
Building dependency tree...
Reading state information...
The following additional packages will be installed:
amd64-microcode firmware-sof-signed grub-common grub-gfxpayload-lists
grub-pc grub-pc-bin grub2-common intel-microcode iucode-tool
libdbus-glib-1-2 libevdev2 libimobiledevice6 libplist3 libupower-glib3
libusbmuxd6 linux-firmware linux-headers-5.15.0-89
linux-headers-5.15.0-89-generic linux-headers-generic
linux-image-5.15.0-89-generic linux-image-generic
linux-modules-5.15.0-89-generic linux-modules-extra-5.15.0-89-generic
os-prober thermald upower usbmuxd wireless-regdb
Suggested packages:
multiboot-doc grub-emu mtools xorriso desktop-base libusbmuxd-tools fdutils
linux-doc | linux-source-5.15.0 linux-tools
The following NEW packages will be installed:
libusbmuxd6 linux-firmware linux-generic linux-headers-5.15.0-89
0 upgraded, 29 newly installed, 0 to remove and 1 not upgraded.
Need to get 385 MB of archives.
After this operation, 1652 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 firmware-sof-signed all 2.0-1ubuntu4.4 [1287 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub-common amd64 2.06-2ubuntu7.2 [2214 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub2-common amd64 2.06-2ubuntu7.2 [652 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub-pc-bin amd64 2.06-2ubuntu7.2 [1083 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub-pc amd64 2.06-2ubuntu7.2 [132 kB]
Get:6 http://archive.ubuntu.com/ubuntu jammy/main amd64 grub-gfxpayload-lists amd64 0.7 [3658 B]
Get:7 http://archive.ubuntu.com/ubuntu jammy/main amd64 iucode-tool amd64 2.3.1-1build1 [46.9 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 libdbus-glib-1-2 amd64 0.112-2build1 [65.4 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy/main amd64 libplist3 amd64 2.2.0-6build2 [32.1 kB]
Get:10 http://archive.ubuntu.com/ubuntu jammy/main amd64 libusbmuxd6 amd64 2.0.2-3build2 [20.4 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy/main amd64 libimobiledevice6 amd64 1.3.0-6build3 [71.1 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy/main amd64 libupower-glib3 amd64 0.99.17-1 [46.7 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-firmware all 20220329.git681281e4-0ubuntu3.23 [259 MB]
Get:14 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-modules-5.15.0-89-generic amd64 5.15.0-89.99 [22.4 MB]
Get:15 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-image-5.15.0-89-generic amd64 5.15.0-89.99 [11.5 MB]
Get:16 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 wireless-regdb all 2022.06.06-0ubuntu1~22.04.1 [10.3 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-modules-extra-5.15.0-89-generic amd64 5.15.0-89.99 [63.9 MB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 intel-microcode amd64 3.20231114.0ubuntu0.22.04.1 [6047 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 amd64-microcode amd64 3.20191218.1ubuntu2.2 [69.0 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-image-generic amd64 5.15.0.89.86 [2492 B]
Get:21 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-5.15.0-89 all 5.15.0-89.99 [12.3 MB]
Get:22 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-5.15.0-89-generic amd64 5.15.0-89.99 [2885 kB]
Get:23 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-headers-generic amd64 5.15.0.89.86 [2336 B]
Get:24 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-generic amd64 5.15.0.89.86 [1698 B]
Get:25 http://archive.ubuntu.com/ubuntu jammy/main amd64 os-prober amd64 1.79ubuntu2 [19.3 kB]
Get:26 http://archive.ubuntu.com/ubuntu jammy/main amd64 libevdev2 amd64 1.12.1+dfsg-1 [39.5 kB]
Get:27 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 thermald amd64 2.4.9-1ubuntu0.4 [222 kB]
Get:28 http://archive.ubuntu.com/ubuntu jammy/main amd64 upower amd64 0.99.17-1 [86.7 kB]
Get:29 http://archive.ubuntu.com/ubuntu jammy/main amd64 usbmuxd amd64 1.1.1-2build2 [42.8 kB]
Preconfiguring packages ...
Fetched 385 MB in 13s (29.8 MB/s)
E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device)
Selecting previously unselected package firmware-sof-signed.
(Reading database ... 33919 files and directories currently installed.)
Preparing to unpack .../00-firmware-sof-signed_2.0-1ubuntu4.4_all.deb ...
Unpacking firmware-sof-signed (2.0-1ubuntu4.4) ...
Selecting previously unselected package grub-common.
Preparing to unpack .../01-grub-common_2.06-2ubuntu7.2_amd64.deb ...
Unpacking grub-common (2.06-2ubuntu7.2) ...
Selecting previously unselected package grub2-common.
Preparing to unpack .../02-grub2-common_2.06-2ubuntu7.2_amd64.deb ...
Unpacking grub2-common (2.06-2ubuntu7.2) ...
Selecting previously unselected package grub-pc-bin.
Preparing to unpack .../03-grub-pc-bin_2.06-2ubuntu7.2_amd64.deb ...
Unpacking grub-pc-bin (2.06-2ubuntu7.2) ...
Selecting previously unselected package grub-pc.
Preparing to unpack .../04-grub-pc_2.06-2ubuntu7.2_amd64.deb ...
Unpacking grub-pc (2.06-2ubuntu7.2) ...
Selecting previously unselected package grub-gfxpayload-lists.
Preparing to unpack .../05-grub-gfxpayload-lists_0.7_amd64.deb ...
Unpacking grub-gfxpayload-lists (0.7) ...
Selecting previously unselected package iucode-tool.
Preparing to unpack .../06-iucode-tool_2.3.1-1build1_amd64.deb ...
Unpacking iucode-tool (2.3.1-1build1) ...
Selecting previously unselected package libdbus-glib-1-2:amd64.
Preparing to unpack .../07-libdbus-glib-1-2_0.112-2build1_amd64.deb ...
Unpacking libdbus-glib-1-2:amd64 (0.112-2build1) ...
Selecting previously unselected package libplist3:amd64.
Preparing to unpack .../08-libplist3_2.2.0-6build2_amd64.deb ...
Unpacking libplist3:amd64 (2.2.0-6build2) ...
Selecting previously unselected package libusbmuxd6:amd64.
Preparing to unpack .../09-libusbmuxd6_2.0.2-3build2_amd64.deb ...
Unpacking libusbmuxd6:amd64 (2.0.2-3build2) ...
Selecting previously unselected package libimobiledevice6:amd64.
Preparing to unpack .../10-libimobiledevice6_1.3.0-6build3_amd64.deb ...
Unpacking libimobiledevice6:amd64 (1.3.0-6build3) ...
Selecting previously unselected package libupower-glib3:amd64.
Preparing to unpack .../11-libupower-glib3_0.99.17-1_amd64.deb ...
Unpacking libupower-glib3:amd64 (0.99.17-1) ...
Selecting previously unselected package linux-firmware.
Preparing to unpack .../12-linux-firmware_20220329.git681281e4-0ubuntu3.23_all.deb ...
Unpacking linux-firmware (20220329.git681281e4-0ubuntu3.23) ...
Selecting previously unselected package linux-modules-5.15.0-89-generic.
Preparing to unpack .../13-linux-modules-5.15.0-89-generic_5.15.0-89.99_amd64.deb ...
Unpacking linux-modules-5.15.0-89-generic (5.15.0-89.99) ...
Selecting previously unselected package linux-image-5.15.0-89-generic.
Preparing to unpack .../14-linux-image-5.15.0-89-generic_5.15.0-89.99_amd64.deb ...
Unpacking linux-image-5.15.0-89-generic (5.15.0-89.99) ...
Selecting previously unselected package wireless-regdb.
Preparing to unpack .../15-wireless-regdb_2022.06.06-0ubuntu1~22.04.1_all.deb ...
Unpacking wireless-regdb (2022.06.06-0ubuntu1~22.04.1) ...
Selecting previously unselected package linux-modules-extra-5.15.0-89-generic.
Preparing to unpack .../16-linux-modules-extra-5.15.0-89-generic_5.15.0-89.99_amd64.deb ...
Unpacking linux-modules-extra-5.15.0-89-generic (5.15.0-89.99) ...
Selecting previously unselected package intel-microcode.
Preparing to unpack .../17-intel-microcode_3.20231114.0ubuntu0.22.04.1_amd64.deb ...
Unpacking intel-microcode (3.20231114.0ubuntu0.22.04.1) ...
Selecting previously unselected package amd64-microcode.
Preparing to unpack .../18-amd64-microcode_3.20191218.1ubuntu2.2_amd64.deb ...
Unpacking amd64-microcode (3.20191218.1ubuntu2.2) ...
Selecting previously unselected package linux-image-generic.
Preparing to unpack .../19-linux-image-generic_5.15.0.89.86_amd64.deb ...
Unpacking linux-image-generic (5.15.0.89.86) ...
Selecting previously unselected package linux-headers-5.15.0-89.
Preparing to unpack .../20-linux-headers-5.15.0-89_5.15.0-89.99_all.deb ...
Unpacking linux-headers-5.15.0-89 (5.15.0-89.99) ...
Selecting previously unselected package linux-headers-5.15.0-89-generic.
Preparing to unpack .../21-linux-headers-5.15.0-89-generic_5.15.0-89.99_amd64.deb ...
Unpacking linux-headers-5.15.0-89-generic (5.15.0-89.99) ...
Selecting previously unselected package linux-headers-generic.
Preparing to unpack .../22-linux-headers-generic_5.15.0.89.86_amd64.deb ...
Unpacking linux-headers-generic (5.15.0.89.86) ...
Selecting previously unselected package linux-generic.
Preparing to unpack .../23-linux-generic_5.15.0.89.86_amd64.deb ...
Unpacking linux-generic (5.15.0.89.86) ...
Selecting previously unselected package os-prober.
Preparing to unpack .../24-os-prober_1.79ubuntu2_amd64.deb ...
Unpacking os-prober (1.79ubuntu2) ...
Selecting previously unselected package libevdev2:amd64.
Preparing to unpack .../25-libevdev2_1.12.1+dfsg-1_amd64.deb ...
Unpacking libevdev2:amd64 (1.12.1+dfsg-1) ...
Selecting previously unselected package thermald.
Preparing to unpack .../26-thermald_2.4.9-1ubuntu0.4_amd64.deb ...
Unpacking thermald (2.4.9-1ubuntu0.4) ...
Selecting previously unselected package upower.
Preparing to unpack .../27-upower_0.99.17-1_amd64.deb ...
Unpacking upower (0.99.17-1) ...
Selecting previously unselected package usbmuxd.
Preparing to unpack .../28-usbmuxd_1.1.1-2build2_amd64.deb ...
Unpacking usbmuxd (1.1.1-2build2) ...
Setting up libplist3:amd64 (2.2.0-6build2) ...
Setting up iucode-tool (2.3.1-1build1) ...
Setting up linux-firmware (20220329.git681281e4-0ubuntu3.23) ...
Setting up intel-microcode (3.20231114.0ubuntu0.22.04.1) ...
intel-microcode: microcode will be updated at next boot
Setting up firmware-sof-signed (2.0-1ubuntu4.4) ...
Setting up wireless-regdb (2022.06.06-0ubuntu1~22.04.1) ...
Setting up amd64-microcode (3.20191218.1ubuntu2.2) ...
amd64-microcode: microcode will be updated at next boot
Setting up linux-headers-5.15.0-89 (5.15.0-89.99) ...
Setting up linux-headers-5.15.0-89-generic (5.15.0-89.99) ...
Setting up grub-common (2.06-2ubuntu7.2) ...
Created symlink /etc/systemd/system/multi-user.target.wants/grub-common.service → /lib/systemd/system/grub-common.service.
Created symlink /etc/systemd/system/sleep.target.wants/grub-common.service → /lib/systemd/system/grub-common.service.
Created symlink /etc/systemd/system/multi-user.target.wants/grub-initrd-fallback.service → /lib/systemd/system/grub-initrd-fallback.service.
Created symlink /etc/systemd/system/rescue.target.wants/grub-initrd-fallback.service → /lib/systemd/system/grub-initrd-fallback.service.
Created symlink /etc/systemd/system/emergency.target.wants/grub-initrd-fallback.service → /lib/systemd/system/grub-initrd-fallback.service.
Created symlink /etc/systemd/system/sleep.target.wants/grub-initrd-fallback.service → /lib/systemd/system/grub-initrd-fallback.service.
Running in chroot, ignoring command 'daemon-reload'
/usr/sbin/policy-rc.d returned 101, not running 'start grub-initrd-fallback.service'
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Running in chroot, ignoring request.
invoke-rc.d: policy-rc.d denied execution of start.
Setting up os-prober (1.79ubuntu2) ...
Setting up libdbus-glib-1-2:amd64 (0.112-2build1) ...
Setting up libusbmuxd6:amd64 (2.0.2-3build2) ...
Setting up libupower-glib3:amd64 (0.99.17-1) ...
Setting up libimobiledevice6:amd64 (1.3.0-6build3) ...
Setting up libevdev2:amd64 (1.12.1+dfsg-1) ...
Setting up grub2-common (2.06-2ubuntu7.2) ...
Setting up upower (0.99.17-1) ...
/usr/sbin/policy-rc.d returned 101, not running 'start upower.service'
Setting up linux-headers-generic (5.15.0.89.86) ...
Setting up grub-pc-bin (2.06-2ubuntu7.2) ...
Setting up usbmuxd (1.1.1-2build2) ...
Warning: The home dir /var/lib/usbmux you specified can't be accessed: No such file or directory
Adding system user `usbmux' (UID 113) ...
Adding new user `usbmux' (UID 113) with group `plugdev' ...
ERROR: ld.so: object 'libeatmydata.so' from LD_PRELOAD cannot be preloaded (cannot open shared object file): ignored.
Not creating home directory `/var/lib/usbmux'.
/usr/sbin/policy-rc.d returned 101, not running 'start usbmuxd.service'
Setting up thermald (2.4.9-1ubuntu0.4) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.thermald.service → /lib/systemd/system/thermald.service.
Created symlink /etc/systemd/system/multi-user.target.wants/thermald.service → /lib/systemd/system/thermald.service.
/usr/sbin/policy-rc.d returned 101, not running 'start thermald.service'
Setting up grub-pc (2.06-2ubuntu7.2) ...
Creating config file /etc/default/grub with new version
Setting up grub-gfxpayload-lists (0.7) ...
Setting up linux-image-5.15.0-89-generic (5.15.0-89.99) ...
I: /boot/vmlinuz.old is now a symlink to vmlinuz-5.15.0-89-generic
I: /boot/initrd.img.old is now a symlink to initrd.img-5.15.0-89-generic
I: /boot/vmlinuz is now a symlink to vmlinuz-5.15.0-89-generic
I: /boot/initrd.img is now a symlink to initrd.img-5.15.0-89-generic
Setting up linux-modules-extra-5.15.0-89-generic (5.15.0-89.99) ...
Setting up linux-image-generic (5.15.0.89.86) ...
Setting up linux-generic (5.15.0.89.86) ...
Setting up linux-modules-5.15.0-89-generic (5.15.0-89.99) ...
Processing triggers for dbus (1.12.20-2ubuntu4.1) ...
Processing triggers for install-info (6.8-4build1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for linux-image-5.15.0-89-generic (5.15.0-89.99) ...
NEEDRESTART-VER: 3.5
NEEDRESTART-KCUR: 5.15.0-89-generic
NEEDRESTART-KEXP: 5.15.0-89-generic
NEEDRESTART-KSTA: 1
NEEDRESTART-UCSTA: 1
NEEDRESTART-UCCUR: 0xb000040
NEEDRESTART-UCEXP: 0xb000040
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'apt-get', 'clean'] with allowed return codes [0] (capture=False)
TIMED subp(['udevadm', 'settle']): 0.018
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: SUCCESS: installing kernel
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/setting-up-swap: setting up swap
Running command ['findmnt', '--noheading', '--target', '/tmp/tmp9alwn5nw/target/', '-o', 'FSTYPE'] with allowed return codes [0] (capture=True)
Running command ['sh', '-c', 'rm -f "$1" && umask 0066 && truncate -s 0 "$1" && { chattr +C "$1" || true; } && fallocate -l "${2}M" "$1" && mkswap "$1" || { r=$?; rm -f "$1"; exit $r; }', 'setup_swap', '/tmp/tmp9alwn5nw/target//swap.img', '8192'] with allowed return codes [0] (capture=False)
chattr: Operation not supported while setting flags on /tmp/tmp9alwn5nw/target//swap.img
Setting up swapspace version 1, size = 8 GiB (8589930496 bytes)
no label, UUID=3e2ec79b-41f6-4745-b29f-762005181882
creating swap file '/swap.img' of 8192MB took 0.041 seconds
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/setting-up-swap: SUCCESS: setting up swap
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/apply-networking-config: apply networking config
applying network_config
Checking cloud-init in target [/tmp/tmp9alwn5nw/target] for network configuration passthrough support.
Checking in-target cloud-init for feature: NETWORK_CONFIG_V2
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', '/usr/bin/cloud-init', 'features'] with allowed return codes [0] (capture=True)
cloud-init feature NETWORK_CONFIG_V2 available? True
Passing network configuration through to target: /tmp/tmp9alwn5nw/target
Writing network config to etc/cloud/cloud.cfg.d/50-curtin-networking.cfg: /tmp/tmp9alwn5nw/target/etc/cloud/cloud.cfg.d/50-curtin-networking.cfg
Failed to find legacy network conf file /tmp/tmp9alwn5nw/target/etc/network/interfaces.d/eth0.cfg
Attempting to remove ipv6 privacy extensions
Removing ipv6 privacy extension config file: /tmp/tmp9alwn5nw/target/etc/sysctl.d/10-ipv6-privacy.conf
del_file: removed /tmp/tmp9alwn5nw/target/etc/sysctl.d/10-ipv6-privacy.conf
Injecting fix for ipv6 mtu settings: /tmp/tmp9alwn5nw/target/etc/network/if-pre-up.d/mtuipv6
Injecting fix for ipv6 mtu settings: /tmp/tmp9alwn5nw/target/etc/network/if-up.d/mtuipv6
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/apply-networking-config: SUCCESS: apply networking config
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-etc-fstab: writing etc/fstab
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/writing-etc-fstab: SUCCESS: writing etc/fstab
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-multipath: configuring multipath
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/loop0'] with allowed return codes [0] (capture=True)
/dev/loop0 is multipath device? False
/dev/loop0 is multipath device partition? False
/dev/loop0 is multipath device member? False
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/loop2'] with allowed return codes [0] (capture=True)
/dev/loop2 is multipath device? False
/dev/loop2 is multipath device partition? False
/dev/loop2 is multipath device member? False
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/loop3'] with allowed return codes [0] (capture=True)
/dev/loop3 is multipath device? False
/dev/loop3 is multipath device partition? False
/dev/loop3 is multipath device member? False
Running command ['udevadm', 'info', '--query=property', '--export', '/dev/loop1'] with allowed return codes [0] (capture=True)
/dev/loop1 is multipath device? False
/dev/loop1 is multipath device partition? False
/dev/loop1 is multipath device member? False
/dev/sdb2 is multipath device? False
/dev/sdb2 is multipath device partition? False
/dev/sdb2 is multipath device member? False
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '--nodeps'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/loop0'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/loop1'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/loop2'] with allowed return codes [0] (capture=True)
Running command ['lsblk', '--noheadings', '--bytes', '--pairs', '--output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID', '/dev/loop3'] with allowed return codes [0] (capture=True)
Running command ['blockdev', '--rereadpt', '/dev/sda'] with allowed return codes [0] (capture=True)
TIMED udevadm_settle(): 0.018
Running command ['blkid', '-o', 'full'] with allowed return codes [0] (capture=True)
legacy_detect_multipath found blkid info: {'/dev/loop1': {'TYPE': 'squashfs'}, '/dev/sdb2': {'LABEL': 'root', 'UUID': '11dd6976-f787-429e-9214-696ec2b84447', 'BLOCK_SIZE': '4096', 'TYPE': 'ext4', 'PARTUUID': '18258040-a8e8-4960-861a-0c1e4253dd7a'}, '/dev/sdb1': {'PARTUUID': 'de780532-7f9a-47cc-89f8-f9a545bcc70d'}, '/dev/loop2': {'TYPE': 'squashfs'}, '/dev/loop0': {'TYPE': 'squashfs'}, '/dev/loop3': {'TYPE': 'squashfs'}}
target_devs: ['/dev/sdb2']
/dev/sdb2: 11dd6976-f787-429e-9214-696ec2b84447
Multipath detection found: False
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-multipath: SUCCESS: configuring multipath
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/system-upgrade: updating packages on target system
system_upgrade disabled by config.
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/system-upgrade: SUCCESS: updating packages on target system
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/pollinate-user-agent: configuring pollinate user-agent on target
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/pollinate-user-agent: SUCCESS: configuring pollinate user-agent on target
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/updating-initramfs-configuration: updating initramfs configuration
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-divert', '--list'] with allowed return codes [0] (capture=True)
Restoring update-initramfs in target for initrd updates.
del_file: removed /tmp/tmp9alwn5nw/target/usr/sbin/update-initramfs
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-divert', '--rename', '--remove', '/usr/sbin/update-initramfs'] with allowed return codes [0] (capture=False)
Removing 'local diversion of /usr/sbin/update-initramfs to /usr/sbin/update-initramfs.curtin-disabled'
TIMED subp(['udevadm', 'settle']): 0.024
TIMED subp(['udevadm', 'settle']): 0.021
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'update-initramfs', '-c', '-k', '5.15.0-89-generic'] with allowed return codes [0] (capture=False)
update-initramfs: Generating /boot/initrd.img-5.15.0-89-generic
TIMED subp(['udevadm', 'settle']): 0.020
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/updating-initramfs-configuration: SUCCESS: updating initramfs configuration
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-bootloader: configuring target system bootloader
start: cmd-install/stage-curthooks/builtin/cmd-curthooks/install-grub: installing grub to target devices
setup grub on target /tmp/tmp9alwn5nw/target
checking: {'grub_device': True, 'id': 'sdb', 'model': 'SuperMicro SSD', 'name': 'sdb', 'ptable': 'gpt', 'serial': 'SMC0515D93621C3B5088', 'type': 'disk', 'wipe': 'superblock'}
lookup_disks found: ['ata-SuperMicro_SSD_SMC0515D93621C3B5088', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'ata-SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-1ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part2', 'scsi-0ATA_SuperMicro_SSD_SMC0515D93621C3B5088-part1']
TIMED udevadm_settle(): 0.079
install_devices: ['/dev/sdb']
Generating grub debconf_selections for devices=['/dev/sdb'] uefi=False
Applying grub debconf_selections config:
{'debconf_selections': {'grub': 'grub-pc grub-pc/install_devices multiselect /dev/disk/by-id/scsi-SATA_SuperMicro_SSD_SMC0515D93621C3B5088'}}
The following packages were installed and preseeded, but cannot be unconfigured: ['grub-pc']
installing grub to target=/tmp/tmp9alwn5nw/target devices=['/dev/sdb'] [replace_defaults=None]
grub: moved /tmp/tmp9alwn5nw/target/etc/default/grub.d/50-cloudimg-settings.cfg out of the way
updated /tmp/tmp9alwn5nw/target/etc/default/grub to set: GRUB_CMDLINE_LINUX_DEFAULT=""
Using grub install command: grub-install
Grub install cmds:
[['dpkg-reconfigure', 'grub-pc'], ['update-grub'], ['grub-install', '/dev/sdb']]
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'dpkg-reconfigure', 'grub-pc'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'update-grub'] with allowed return codes [0] (capture=True)
Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmp9alwn5nw/target', 'grub-install', '/dev/sdb'] with allowed return codes [0] (capture=True)
TIMED subp(['udevadm', 'settle']): 0.084
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/install-grub: SUCCESS: installing grub to target devices
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-bootloader: SUCCESS: configuring target system bootloader
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: SUCCESS: curtin command curthooks
start: cmd-install/stage-hook/builtin/cmd-hook: curtin command hook
Finalizing /tmp/tmp9alwn5nw/target
finish: cmd-install/stage-hook/builtin/cmd-hook: SUCCESS: curtin command hook
--2023-12-06 04:56:52-- http://10.10.10.1:5248/MAAS/metadata/latest/by-id/6x8gm6/
Connecting to 10.10.10.1:5248... connected.
Length: 2 [text/plain]
Saving to: ‘/dev/null’
0K 100% 223K=0s
2023-12-06 04:56:52 (223 KB/s) - ‘/dev/null’ saved [2/2]
curtin: Installation finished.
How can I resolve this issue and deploy OS in SSD and use RAID1 Harddisk (18TB) as partition for my server ?
