Hi!
I’ve searched around the forum as suggested by billwear here but has come out empty-handed, someone mentioned a network misconfiguration, but not the resolution. I’ve included a gif recording of the proxmox test-vm I’m testing provisioning with along with a print-screen of the final state.
Sadly searching the forum doesn’t give me much, or anything. The issue appeared out of the wild, I might’ve reconfigured which VLAN’s have DHCP, set the TTL on the builtin DNS server, but trying to revert haven’t helped.
I’ve enabled some extra logging in nginx and squid, i can’t really tell what’s wrong but something about maas-regiond-webapp.sock doesn’t seem to be right.
This discourse is configured to not allow file uploading so I’ve taken the liberty of uploading my logs directory to https://filebin.net/asow7rmjh5h6ulyh.
I’ve seen this issue lingering around since 2017 in various places online when searching, and the resolution seems to be to set MAAS up from scratch and not touch anything related to networking ever again.
root@rvlpmaas03:/var/snap/maas/common# cat /etc/hosts
127.0.0.1 localhost
#127.0.1.1 rvlpmaas03
127.0.0.1 rvlpmaas03
# The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
root@rvlpmaas03:/var/snap/maas/common# cat ../current/regiond.conf
database_host: /var/snap/maas/common/test-db-socket
database_name: maasdb
database_user: maas
maas_url: http://100.64.30.250:5240/MAAS
root@rvlpmaas03:/var/snap/maas/common# cat ../current/rackd.conf
It seems after further testing (after messing with various things) that my vlan 2505 still works while 2407 doesn’t, they both worked earlier.
Any help with troubleshooting to resolve this once and for all and document it for the rest of MAAS users would be greatly appreciated.
