Every network issue in MAAS comes down to the right tool used at the right time. This document catalogus the essential troubleshooting tools, explains how to use them, and shows examples in a MAAS context.
Link and interface state
ip link, ip addr, ip -d link
- Purpose: Show interfaces, addresses, VLAN tagging, bridge membership.
- Example:
ip -d link show dev eno1
- MAAS use: Verify PXE NIC is up and tagged correctly.
ethtool
- Purpose: Show speed, duplex, offloads, driver info.
- Examples:
ethtool eno1
ethtool -k eno1
ethtool -S eno1
- MAAS use: Detect driver quirks that break image downloads.
lldpcli, lldpd
- Purpose: Discover switchport neighbors.
- Example:
lldpcli show neighbors
- MAAS use: Confirm correct switchport and VLAN.
VLANs, bonds, and bridges
bridge link, bridge vlan, bridge fdb
- Show bridge memberships and VLAN info.
Netplan
- Validate configs:
netplan get
netplan try
netplan apply
Open vSwitch
- Example:
ovs-vsctl show
Discovery and reachability
Ping/arping
ping <ip>
arping -I br0 <gateway>
Traceroute/MTR
mtr -ezbwrc 100 <host>
- MAAS use: Spot asymmetric routing or packet loss.
Packet capture and protocol lenses
tcpdump
- General capture:
tcpdump -n -e -vv -s0 -i <iface> -w /tmp/boot.pcap
- Filters:
- DHCP:
port 67 or port 68 - TFTP:
port 69 - DNS:
port 53 - HTTP:
tcp port 80 and host <maas-ip>
- DHCP:
tshark, termshark, ngrep
- In-terminal decodes and quick protocol filters.
Wireshark
- Decode BOOTP/DHCP, follow TCP streams, export boot files.
Service checks
ss -ltnup, ss -uanp
- Show active listeners.
curl, wget, httping
- Test HTTP endpoints.
curl -I http://<maas-host>/MAAS/
nc/ncat/socat
- Check connectivity.
nc -vz <host> 67 69 80 3128
TFTP clients
atftp -g -r pxelinux.0 <tftp-ip>
Name resolution
dig, kdig, host
dig @<dns-ip> <node>.maas A +noall +answer +ttl
resolvectl status
- Inspect systemd-resolved configuration.
Time sync
chronyc, timedatectl, ntpq
chronyc sources -v
- MAAS use: Ensure clocks are in sync for commissioning.
Performance profiling
iperf3
iperf3 -c <server> -P 4 -t 30
nload, iftop, bmon
- Real-time bandwidth monitoring.
TCP info
ss -ti
Logs and events
Systemd journals
journalctl -u snap.maas.regiond -u snap.maas.rackd
MAAS event logs
maas $PROFILE events query level=WARNING
Installer logs
/var/log/cloud-init.log/var/log/curtin/install.log/var/log/installer/*
Firewalls and ACLs
nft, iptables, ufw
nft list ruleset
- MAAS use: Verify PXE/DHCP/DNS/TFTP/HTTP not blocked.
Next steps
With these tools in your belt, the next reference dives into MAAS‑specific deep dives: how PXE, DHCP, metadata, and proxies behave in detail.
