Not exactly a bug but with multipath SAS devices, you see all disks twice or more. Would be better if Maas could distinguish between multipath and single path devices and for multipath use /dev/mapper.
It does create a problem where for example when you do smartctl or badblock test you do everything twice, plus you don’t really see the device you are going to use, e.g. when deploying Ceph OSDs.
Thanks
