Megaraid disks not detected in MAAS 3.1.0 with Smartctl-validate
Hi, I have an old Dell PowerEdge 1850 with a Megaraid controller and MAAS is unable to detect the storage as it is unable to handle the Megaraid controller? How can I get this to work?
This is the error messages from the script “smartctl-validate”
Unable to run ‘smartctl-validate’: ‘MAAS did not detect any storage devices during commissioning!’
Given parameters:
{‘storage’: {‘argument_format’: ‘{path}’, ‘type’: ‘storage’, ‘value’: ‘all’}}
Discovered storage devices:
[{‘NAME’: ‘sr0’, ‘MODEL’: ‘HL-DT-STCD-RW_DVD-ROM_GCC-4244N’, ‘SERIAL’: ‘’, ‘MAJ:MIN’: ‘11:0’, ‘MODEL_ENC’: ‘HL-DT-STCD-RW/DVD-ROM GCC-4244N’}]
Discovered interfaces:
{‘00:13:72:58:d6:d5’: ‘enp6s7’}
Thanks
Hi, @cadourian,
Can you give us a little more information?
Identify your version and build
We need to know the version and build (and packaging format) that you’re running. You mentioned 3.1, but we need a little more information.
If you’re using a snap
If you’re using a snap, execute snap listmaas at the command line, which will return some lines like this:
Name  Version                       Rev    Tracking     Publisher   Notes
maas  3.0.0~beta2-9796-g.2182ab55f  13292  latest/edge  canonical✓  -
Please add the output of that command to a comment on this post.
If you’re using a Debian package
If you’re using a deb, execute apt list maas at the command line, and enter whatever it returns into a comment to this post, as in the snap example above.
Using CLI, UI, or API?
Next, you’ll need to specify which interface you’re using, and generally what command(s) you were attempting.
Explain what happens
Being as concise and specific as you can, please explain a little more about what seemed to go wrong. You mentioned that commissioned machines don’t show any storage? Can you show us some screenshots of an 1850 that commissions with no storage, for example? Maybe it’s not getting past smartctl-validate?
Explain how to reproduce your issue
In addition to the explanation above, you should create a step-by-step list of what you did to reproduce the problem. Sounds like it’s pretty simple – just try to commission a machine – but we’d like to be sure.
Take relevant screenshots
If you think it will help – especially when using the UI – try and capture screenshots of any unexpected results or ambiguous actions. Your goal isn’t to document your experience in pictures, but to provide a visual reference where verbal descriptions fall short. Name these so you can sync them with your explanation (e.g., “screenshot-1”). You can just upload them into your comment.
Locate and capture logfiles
If at all possible, capture at least the following logfiles, for the time period surrounding your error situation:
  1. maas.log
  2. regiond.log
  3. rackd.log
  4. the rsyslog file of the affected machine(s), if it exists.
On snap, these files are located as follows:
  • /var/snap/maas/common/log/maas.log
  • /var/snap/maas/common/log/regiond.log
  • /var/snap/maas/common/log/rackd.log
  • /var/snap/maas/common/log/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
If you’re using packages, you’ll find the files in these locations:
  • /var/log/maas/maas.log
  • /var/log/maas/regiond.log
  • /var/log/maas/rackd.log
  • /var/log/maas/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
Ideally, you’d want to put these in a pastebin and link the pastebin location in your comment.
Thanks for this. We’ll need this additional information in order to try and figure out what’s going on.
I’ll try to provide all the info requested
MAAS Version:
maas 3.1.0-10901-g.f1f8f1505 18199 3.1/stable canonical✓ -
I was doing the “Commission” of a Dell PowerEdge 1850 that uses a Megaraid Controller.
This machine has two disks in some RAID configuration. It boots its local Ubuntu successfully.
During the boot, the BIOS does not detect any Virtual drives - I guess RAID disks don’t show in that stage but then it boots into the OS as expected.
As you say, what’s failing is “smartctl-validate”. No disks are visible in Smartctl-validate. I’ll see if I have any logs I can provide for this machine.
I can’t send you all my logs, but I can try to send you portions of it as needed. Here’s for a start the maas.log.
Please let me know if you need more and I will provide it.
I can also re-hookup this machine and repeat the process.
The main message is “Unable to set any default storage layout because it has no writable disks.”
2022-03-04T23:27:58.674381+00:00 atxds02 maas.node: [info] 21 (10.10.21.181:type=STICKY): Deleting BMC
2022-03-04T23:28:51.891454+00:00 atxds02 maas.node: [info] pe1850: Status transition from NEW to COMMISSIONING
2022-03-04T23:28:51.974022+00:00 atxds02 maas.power: [info] Changing power state (on) of node: pe1850 (66abr4)
2022-03-04T23:28:51.974392+00:00 atxds02 maas.node: [info] pe1850: Commissioning started
2022-03-04T23:28:59.294289+00:00 atxds02 maas.power: [info] Changed power state (on) of node: pe1850 (66abr4)
2022-03-04T23:29:14.700021+00:00 atxds02 maas.power: [info] Changing power state (off) of node: pe1850 (66abr4)
2022-03-04T23:29:14.712672+00:00 atxds02 maas.node: [info] pe1850: Status transition from COMMISSIONING to NEW
2022-03-04T23:29:14.730138+00:00 atxds02 maas.node: [info] pe1850: Commissioning aborted, stopping machine
2022-03-04T23:29:20.181194+00:00 atxds02 maas.power: [info] Changed power state (off) of node: pe1850 (66abr4)
2022-03-04T23:29:33.160143+00:00 atxds02 maas.node: [info] pe1850: Status transition from NEW to COMMISSIONING
2022-03-04T23:29:33.229262+00:00 atxds02 maas.power: [info] Changing power state (on) of node: pe1850 (66abr4)
2022-03-04T23:29:33.229668+00:00 atxds02 maas.node: [info] pe1850: Commissioning started
2022-03-04T23:29:41.317397+00:00 atxds02 maas.power: [info] Changed power state (on) of node: pe1850 (66abr4)
2022-03-04T23:36:44.570342+00:00 atxds02 maas.node: [error] pe1850: Unable to set any default storage layout because it has no writable disks.
2022-03-04T23:37:18.218022+00:00 atxds02 maas.node: [info] pe1850: Status transition from COMMISSIONING to TESTING
2022-03-04T23:37:30.115990+00:00 atxds02 maas.node: [info] pe1850: Status transition from TESTING to FAILED_TESTING
2022-03-04T23:40:38.741364+00:00 atxds02 maas.node: [info] pe1850: Status transition from FAILED_TESTING to BROKEN
2022-03-04T23:41:37.399723+00:00 atxds02 maas.node: [info] pe1850: Status transition from BROKEN to ENTERING_RESCUE_MODE
2022-03-04T23:41:37.452605+00:00 atxds02 maas.power: [info] Changing power state (cycle) of node: pe1850 (66abr4)
2022-03-04T23:41:37.452919+00:00 atxds02 maas.node: [info] pe1850: Rescue mode starting
2022-03-04T23:41:45.714188+00:00 atxds02 maas.power: [info] Changed power state (on) of node: pe1850 (66abr4)
2022-03-04T23:41:59.086728+00:00 atxds02 maas.node: [info] pe1850: Status transition from ENTERING_RESCUE_MODE to EXITING_RESCUE_MODE
2022-03-04T23:41:59.181420+00:00 atxds02 maas.power: [info] Changing power state (off) of node: pe1850 (66abr4)
2022-03-04T23:42:04.622940+00:00 atxds02 maas.node: [info] pe1850: Status transition from EXITING_RESCUE_MODE to BROKEN
2022-03-04T23:42:04.668220+00:00 atxds02 maas.power: [info] Changed power state (off) of node: pe1850 (66abr4)
2022-03-04T23:42:36.553867+00:00 atxds02 maas.interface: [info] enp6s7 (physical) on pe1850: IP address automatically unlinked: None:type=AUTO
2022-03-04T23:42:36.569418+00:00 atxds02 maas.node: [info] pe1850: Status transition from BROKEN to COMMISSIONING
2022-03-04T23:42:36.958500+00:00 atxds02 maas.power: [info] Changing power state (on) of node: pe1850 (66abr4)
2022-03-04T23:42:36.958847+00:00 atxds02 maas.node: [info] pe1850: Commissioning started
2022-03-04T23:42:44.338650+00:00 atxds02 maas.power: [info] Changed power state (on) of node: pe1850 (66abr4)
2022-03-04T23:49:44.948577+00:00 atxds02 maas.node: [error] pe1850: Unable to set any default storage layout because it has no writable disks.
Cheers
Chahe’
thanks, @cadourian! this is enough to start looking at this. will keep you posted.
hey, @cadourian,
What do you see if you do the following?
/opt/MegaRAID/MegaCli/MegaCli64 -adpgetpciinfo -a0 | grep Bus
ls /sys/bus/pci/devices/0000\:0${BUS_ID}\:00.0/  | grep host
ls /sys/bus/pci/devices/0000\:0${BUS_ID}\:00.0/${HOST_ID}/
# check if previous ID is in:
lsscsi
Hey, @billwear,
I wasn’t able to boot into the system. Something may be broken with the machine.
I had another PowerEdge 1850 and I was able to commission it.
The two 1850 machines may be configured differently.
  • the one that was failing, at boot, it would say “0 virtual disks detected”
  • the one that is working detects virtual disks at boot.
I thank you for you getting back to me. If this is important, I will compare the BIOS settings, particularly RAID config etc and try to boot into the “failing” machine’s OS to get you your answers. I myself am not going to use the PowerEdge 1850 as it’s too old.
Cheers
I had a similar issue with brand new Dell X740xd and the fix for it was creating a virtual disk. Even though in my case, we should be able to configure the Perc 750 for HBA mode.
@cadourian, we’ll wait for your ping on this. we’ll be here if you decide to brave those waters again.
