I just managed to test successfully another host with 2 SSD’s in the RAID group, but with 3 disks I end up with this. Is this a bug in 24.04’s mdadm or what? This server successfully deploys 22.04.
Generating device storage trees for path(s): [‘/dev/nvme3n1’, ‘/dev/nvme0n1’, ‘/dev/nvme1n1’, ‘/dev/nvme2n1’]
devname ‘/sys/class/block/nvme3n1’ had holders: []
/dev/nvme3n1 is multipath device partition? False
devname ‘/sys/class/block/nvme0n1’ had holders: []
/dev/nvme0n1 is multipath device partition? False
devname ‘/sys/class/block/nvme1n1’ had holders: []
/dev/nvme1n1 is multipath device partition? False
devname ‘/sys/class/block/nvme2n1’ had holders: []
/dev/nvme2n1 is multipath device partition? False
Current device storage tree:
nvme3n1
nvme0n1
nvme1n1
nvme2n1
Shutdown Plan:
{‘level’: 0, ‘device’: ‘/sys/class/block/nvme0n1’, ‘dev_type’: ‘disk’}
{‘level’: 0, ‘device’: ‘/sys/class/block/nvme1n1’, ‘dev_type’: ‘disk’}
{‘level’: 0, ‘device’: ‘/sys/class/block/nvme2n1’, ‘dev_type’: ‘disk’}
{‘level’: 0, ‘device’: ‘/sys/class/block/nvme3n1’, ‘dev_type’: ‘disk’}
shutdown running on holder type: ‘disk’ syspath: ‘/sys/class/block/nvme0n1’
Running command [‘lsblk’, ‘–noheadings’, ‘–bytes’, ‘–pairs’, ‘–output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID’, ‘/dev/nvme0n1’] with allowed return codes [0] (capture=True)
get_blockdev_sector_size: info:
“nvme0n1”: {
“ALIGNMENT”: “0”,
“DISC-ALN”: “0”,
“DISC-GRAN”: “512”,
“DISC-MAX”: “2199023255040”,
“DISC-ZERO”: “0”,
“FSTYPE”: “”,
“GROUP”: “disk”,
“KNAME”: “nvme0n1”,
“LABEL”: “”,
“LOG-SEC”: “512”,
“MAJ:MIN”: “259:1”,
“MIN-IO”: “512”,
“MODE”: “brw-rw----”,
“MODEL”: “Dell Ent NVMe PM1735a MU 1.6TB”,
“MOUNTPOINT”: “”,
“NAME”: “nvme0n1”,
“OPT-IO”: “0”,
“OWNER”: “root”,
“PHY-SEC”: “512”,
“RM”: “0”,
“RO”: “0”,
“ROTA”: “0”,
“RQ-SIZE”: “”,
“SIZE”: “1600321314816”,
“STATE”: “”,
“TYPE”: “disk”,
“UUID”: “”,
“device_path”: “/dev/nvme0n1”
get_blockdev_sector_size: (log=512, phys=512)
Running command [‘fdasd’, ‘–table’, ‘/dev/nvme0n1’] with allowed return codes [0] (capture=False)
Running command [‘lsblk’, ‘–noheadings’, ‘–bytes’, ‘–pairs’, ‘–output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID’] with allowed return codes [0] (capture=True)
Checking if /dev/nvme0n1 is a swap device
Found swap magic: b’\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00’
Running command [‘udevadm’, ‘info’, ‘–query=property’, ‘–export’, ‘/dev/nvme0n1’] with allowed return codes [0] (capture=True)
/dev/nvme0n1 is multipath device? False
/dev/nvme0n1 is multipath device member? False
wiping superblock on /dev/nvme0n1
wiping /dev/nvme0n1 attempt 1/4
wiping 1M on /dev/nvme0n1 at offsets [0, -1048576]
successfully wiped device /dev/nvme0n1 on attempt 1/4
shutdown running on holder type: ‘disk’ syspath: ‘/sys/class/block/nvme1n1’
Running command [‘lsblk’, ‘–noheadings’, ‘–bytes’, ‘–pairs’, ‘–output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID’, ‘/dev/nvme1n1’] with allowed return codes [0] (capture=True)
“nvme1n1”: {
“ALIGNMENT”: “0”,
“DISC-ALN”: “0”,
“DISC-GRAN”: “512”,
“DISC-ZERO”: “0”,
“FSTYPE”: “”,
“GROUP”: “disk”,
“KNAME”: “nvme1n1”,
“LABEL”: “”,
“LOG-SEC”: “512”,
“MAJ:MIN”: “259:3”,
“MIN-IO”: “512”,
“MOUNTPOINT”: “”,
“NAME”: “nvme1n1”,
“OPT-IO”: “0”,
“OWNER”: “root”,
“PHY-SEC”: “512”,
“RM”: “0”,
“RO”: “0”,
“ROTA”: “0”,
“RQ-SIZE”: “”,
“STATE”: “”,
“TYPE”: “disk”,
“UUID”: “”,
“device_path”: “/dev/nvme1n1”
Running command [‘fdasd’, ‘–table’, ‘/dev/nvme1n1’] with allowed return codes [0] (capture=False)
Checking if /dev/nvme1n1 is a swap device
Running command [‘udevadm’, ‘info’, ‘–query=property’, ‘–export’, ‘/dev/nvme1n1’] with allowed return codes [0] (capture=True)
/dev/nvme1n1 is multipath device? False
/dev/nvme1n1 is multipath device member? False
wiping superblock on /dev/nvme1n1
wiping /dev/nvme1n1 attempt 1/4
wiping 1M on /dev/nvme1n1 at offsets [0, -1048576]
successfully wiped device /dev/nvme1n1 on attempt 1/4
shutdown running on holder type: ‘disk’ syspath: ‘/sys/class/block/nvme2n1’
Running command [‘lsblk’, ‘–noheadings’, ‘–bytes’, ‘–pairs’, ‘–output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID’, ‘/dev/nvme2n1’] with allowed return codes [0] (capture=True)
“nvme2n1”: {
“ALIGNMENT”: “0”,
“DISC-ALN”: “0”,
“DISC-GRAN”: “512”,
“DISC-ZERO”: “0”,
“FSTYPE”: “”,
“GROUP”: “disk”,
“KNAME”: “nvme2n1”,
“LABEL”: “”,
“LOG-SEC”: “512”,
“MAJ:MIN”: “259:5”,
“MIN-IO”: “512”,
“MOUNTPOINT”: “”,
“NAME”: “nvme2n1”,
“OPT-IO”: “0”,
“OWNER”: “root”,
“PHY-SEC”: “512”,
“RM”: “0”,
“RO”: “0”,
“ROTA”: “0”,
“RQ-SIZE”: “”,
“STATE”: “”,
“TYPE”: “disk”,
“UUID”: “”,
“device_path”: “/dev/nvme2n1”
Running command [‘fdasd’, ‘–table’, ‘/dev/nvme2n1’] with allowed return codes [0] (capture=False)
Checking if /dev/nvme2n1 is a swap device
Running command [‘udevadm’, ‘info’, ‘–query=property’, ‘–export’, ‘/dev/nvme2n1’] with allowed return codes [0] (capture=True)
/dev/nvme2n1 is multipath device? False
/dev/nvme2n1 is multipath device member? False
wiping superblock on /dev/nvme2n1
wiping /dev/nvme2n1 attempt 1/4
wiping 1M on /dev/nvme2n1 at offsets [0, -1048576]
successfully wiped device /dev/nvme2n1 on attempt 1/4
shutdown running on holder type: ‘disk’ syspath: ‘/sys/class/block/nvme3n1’
Running command [‘lsblk’, ‘–noheadings’, ‘–bytes’, ‘–pairs’, ‘–output=ALIGNMENT,DISC-ALN,DISC-GRAN,DISC-MAX,DISC-ZERO,FSTYPE,GROUP,KNAME,LABEL,LOG-SEC,MAJ:MIN,MIN-IO,MODE,MODEL,MOUNTPOINT,NAME,OPT-IO,OWNER,PHY-SEC,RM,RO,ROTA,RQ-SIZE,SIZE,STATE,TYPE,UUID’, ‘/dev/nvme3n1’] with allowed return codes [0] (capture=True)
“nvme3n1”: {
“ALIGNMENT”: “0”,
“DISC-ALN”: “0”,
“DISC-GRAN”: “512”,
“DISC-ZERO”: “0”,
“FSTYPE”: “”,
“GROUP”: “disk”,
“KNAME”: “nvme3n1”,
“LABEL”: “”,
“LOG-SEC”: “512”,
“MAJ:MIN”: “259:7”,
“MIN-IO”: “512”,
“MODEL”: “Dell BOSS-N1”,
“MOUNTPOINT”: “”,
“NAME”: “nvme3n1”,
“OPT-IO”: “0”,
“OWNER”: “root”,
“PHY-SEC”: “512”,
“RM”: “0”,
“RO”: “0”,
“ROTA”: “0”,
“RQ-SIZE”: “”,
“SIZE”: “480036519936”,
“STATE”: “”,
“TYPE”: “disk”,
“UUID”: “”,
“device_path”: “/dev/nvme3n1”
Running command [‘fdasd’, ‘–table’, ‘/dev/nvme3n1’] with allowed return codes [0] (capture=False)
Checking if /dev/nvme3n1 is a swap device
Running command [‘udevadm’, ‘info’, ‘–query=property’, ‘–export’, ‘/dev/nvme3n1’] with allowed return codes [0] (capture=True)
/dev/nvme3n1 is multipath device? False
/dev/nvme3n1 is multipath device member? False
wiping superblock on /dev/nvme3n1
wiping /dev/nvme3n1 attempt 1/4
wiping 1M on /dev/nvme3n1 at offsets [0, -1048576]
successfully wiped device /dev/nvme3n1 on attempt 1/4
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta/clear-holders: SUCCESS: removing previous storage devices
blockmeta: detected storage config, using mode=custom
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: nvme0n1
get_path_to_storage_volume for volume nvme0n1({‘grub_device’: True, ‘id’: ‘nvme0n1’, ‘model’: ‘Dell BOSS-N1’, ‘name’: ‘nvme0n1’, ‘ptable’: ‘gpt’, ‘serial’: ‘CN0WW56VFCP003CD00UI’, ‘type’: ‘disk’, ‘wipe’: ‘superblock’})
Processing serial CN0WW56VFCP003CD00UI via udev to CN0WW56VFCP003CD00UI
lookup_disks found: [‘nvme-Dell_BOSS-N1_CN0WW56VFCP003CD00UI’, ‘nvme-Dell_BOSS-N1_CN0WW56VFCP003CD00UI_1’]
block.lookup_disk() returning path /dev/nvme3n1
Running command [‘partprobe’, ‘/dev/nvme3n1’] with allowed return codes [0, 1] (capture=False)
Running command [‘udevadm’, ‘settle’] with allowed return codes [0] (capture=False)
TIMED udevadm_settle(): 0.013
devsync happy - path /dev/nvme3n1 now exists
return volume path /dev/nvme3n1
labeling device: ‘/dev/nvme3n1’ with ‘gpt’ partition table
devname ‘/dev/nvme3n1’ had holders: []
TIMED udevadm_settle(): 0.014
Running command [‘blkid’, ‘-o’, ‘export’, ‘/dev/nvme3n1’] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“disk”’, ‘ENV{ID_WWN}==“eui.0050430e08000001”’, ‘ENV{ID_SERIAL}==“Dell_BOSS-N1_CN0WW56VFCP003CD00UI_1”’, ‘ENV{ID_SERIAL_SHORT}==“CN0WW56VFCP003CD00UI”’, ‘SYMLINK+=“disk/by-dname/nvme0n1”\n’]’
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“partition”’, ‘ENV{ID_WWN}==“eui.0050430e08000001”’, ‘ENV{ID_SERIAL}==“Dell_BOSS-N1_CN0WW56VFCP003CD00UI_1”’, ‘ENV{ID_SERIAL_SHORT}==“CN0WW56VFCP003CD00UI”’, ‘SYMLINK+=“disk/by-dname/nvme0n1-part%n”\n’]’
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: nvme0n1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: nvme1n1
get_path_to_storage_volume for volume nvme1n1({‘id’: ‘nvme1n1’, ‘model’: ‘Dell Ent NVMe PM1735a MU 1.6TB’, ‘name’: ‘nvme1n1’, ‘serial’: ‘S6UVNC0X101100’, ‘type’: ‘disk’, ‘wipe’: ‘superblock’})
Processing serial S6UVNC0X101100 via udev to S6UVNC0X101100
lookup_disks found: [‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101100’, ‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101100_1’]
block.lookup_disk() returning path /dev/nvme0n1
Running command [‘partprobe’, ‘/dev/nvme0n1’] with allowed return codes [0, 1] (capture=False)
TIMED udevadm_settle(): 0.012
devsync happy - path /dev/nvme0n1 now exists
return volume path /dev/nvme0n1
devname ‘/dev/nvme0n1’ had holders: []
TIMED udevadm_settle(): 0.019
Running command [‘blkid’, ‘-o’, ‘export’, ‘/dev/nvme0n1’] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“disk”’, ‘ENV{ID_WWN}==“eui.36555630581011000025384300000003”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101100_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101100”’, ‘SYMLINK+=“disk/by-dname/nvme1n1”\n’]’
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“partition”’, ‘ENV{ID_WWN}==“eui.36555630581011000025384300000003”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101100_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101100”’, ‘SYMLINK+=“disk/by-dname/nvme1n1-part%n”\n’]’
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: nvme1n1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: nvme2n1
get_path_to_storage_volume for volume nvme2n1({‘id’: ‘nvme2n1’, ‘model’: ‘Dell Ent NVMe PM1735a MU 1.6TB’, ‘name’: ‘nvme2n1’, ‘serial’: ‘S6UVNC0X101119’, ‘type’: ‘disk’, ‘wipe’: ‘superblock’})
Processing serial S6UVNC0X101119 via udev to S6UVNC0X101119
lookup_disks found: [‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101119’, ‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101119_1’]
block.lookup_disk() returning path /dev/nvme1n1
Running command [‘partprobe’, ‘/dev/nvme1n1’] with allowed return codes [0, 1] (capture=False)
devsync happy - path /dev/nvme1n1 now exists
return volume path /dev/nvme1n1
devname ‘/dev/nvme1n1’ had holders: []
TIMED udevadm_settle(): 0.017
Running command [‘blkid’, ‘-o’, ‘export’, ‘/dev/nvme1n1’] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“disk”’, ‘ENV{ID_WWN}==“eui.36555630581011190025384300000002”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101119_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101119”’, ‘SYMLINK+=“disk/by-dname/nvme2n1”\n’]’
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“partition”’, ‘ENV{ID_WWN}==“eui.36555630581011190025384300000002”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101119_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101119”’, ‘SYMLINK+=“disk/by-dname/nvme2n1-part%n”\n’]’
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: nvme2n1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring disk: nvme3n1
get_path_to_storage_volume for volume nvme3n1({‘id’: ‘nvme3n1’, ‘model’: ‘Dell Ent NVMe PM1735a MU 1.6TB’, ‘name’: ‘nvme3n1’, ‘serial’: ‘S6UVNC0X101118’, ‘type’: ‘disk’, ‘wipe’: ‘superblock’})
Processing serial S6UVNC0X101118 via udev to S6UVNC0X101118
lookup_disks found: [‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101118’, ‘nvme-Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101118_1’]
block.lookup_disk() returning path /dev/nvme2n1
Running command [‘partprobe’, ‘/dev/nvme2n1’] with allowed return codes [0, 1] (capture=False)
devsync happy - path /dev/nvme2n1 now exists
return volume path /dev/nvme2n1
devname ‘/dev/nvme2n1’ had holders: []
Running command [‘blkid’, ‘-o’, ‘export’, ‘/dev/nvme2n1’] with allowed return codes [0, 2] (capture=True)
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“disk”’, ‘ENV{ID_WWN}==“eui.36555630581011180025384300000002”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101118_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101118”’, ‘SYMLINK+=“disk/by-dname/nvme3n1”\n’]’
Creating dname udev rule ‘[‘SUBSYSTEM==“block”’, ‘ACTION==“add|change”’, ‘ENV{DEVTYPE}==“partition”’, ‘ENV{ID_WWN}==“eui.36555630581011180025384300000002”’, ‘ENV{ID_SERIAL}==“Dell_Ent_NVMe_PM1735a_MU_1.6TB_S6UVNC0X101118_1”’, ‘ENV{ID_SERIAL_SHORT}==“S6UVNC0X101118”’, ‘SYMLINK+=“disk/by-dname/nvme3n1-part%n”\n’]’
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: SUCCESS: configuring disk: nvme3n1
start: cmd-install/stage-partitioning/builtin/cmd-block-meta: configuring raid: md0
raid: cfg: {
“devices”: [
“nvme1n1”,
“nvme2n1”,
“nvme3n1”
“id”: “md0”,
“name”: “md0”,
“raidlevel”: 0,
“spare_devices”: [],
“type”: “raid”
TIMED udevadm_settle(): 0.016
TIMED udevadm_settle(): 0.023
raid: device path mapping: <zip object at 0x7fa974ab6080>
mdadm_create: md_name=/dev/md0 raidlevel=0 devices=[‘/dev/nvme0n1’, ‘/dev/nvme1n1’, ‘/dev/nvme2n1’] spares=[] name=
Running command [‘hostname’, ‘-s’] with allowed return codes [0] (capture=True)
Running command [‘mdadm’, ‘–examine’, ‘/dev/nvme0n1’] with allowed return codes [0] (capture=True)
not a valid md member device: /dev/nvme0n1
/dev/nvme0n1 not mdadm member, force=False so skiping zeroing
Running command [‘mdadm’, ‘–examine’, ‘/dev/nvme1n1’] with allowed return codes [0] (capture=True)
not a valid md member device: /dev/nvme1n1
/dev/nvme1n1 not mdadm member, force=False so skiping zeroing
Running command [‘mdadm’, ‘–examine’, ‘/dev/nvme2n1’] with allowed return codes [0] (capture=True)
not a valid md member device: /dev/nvme2n1
/dev/nvme2n1 not mdadm member, force=False so skiping zeroing
TIMED udevadm_settle(): 0.008
Running command [‘udevadm’, ‘control’, ‘–stop-exec-queue’] with allowed return codes [0] (capture=False)
Running command [‘mdadm’, ‘–create’, ‘/dev/md0’, ‘–run’, ‘–homehost=R660-solid-bengal’, ‘–raid-devices=3’, ‘–metadata=default’, ‘–level=0’, ‘/dev/nvme0n1’, ‘/dev/nvme1n1’, ‘/dev/nvme2n1’] with allowed return codes [0] (capture=True)
mdadm_create failed - extra debug regarding md modules
Running command [‘lsmod’] with allowed return codes [0] (capture=True)
modules loaded:
Module Size Used by
bcache 409600 0
zfs 6680576 0
spl 188416 1 zfs
tls 151552 0
dm_multipath 45056 0
overlay 212992 1
btrfs 2019328 0
blake2b_generic 24576 0
raid10 73728 0
raid456 192512 0
async_raid6_recov 20480 1 raid456
async_memcpy 16384 2 raid456,async_raid6_recov
async_pq 20480 2 raid456,async_raid6_recov
async_xor 16384 3 async_pq,raid456,async_raid6_recov
async_tx 16384 5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor 20480 2 async_xor,btrfs
raid6_pq 126976 4 async_pq,btrfs,raid456,async_raid6_recov
libcrc32c 12288 2 btrfs,raid456
raid1 57344 0
raid0 24576 0
crct10dif_pclmul 12288 1
crc32_pclmul 12288 0
polyval_clmulni 12288 0
ipmi_ssif 45056 0
polyval_generic 12288 1 polyval_clmulni
dax_hmem 16384 0
ghash_clmulni_intel 16384 0
cxl_acpi 24576 0
sha256_ssse3 32768 0
nvme 61440 0
ahci 49152 0
cxl_core 299008 1 cxl_acpi
sha1_ssse3 32768 0
bnxt_en 417792 0
nvme_core 212992 1 nvme
xhci_pci 24576 0
tg3 229376 0
libahci 57344 1 ahci
ipmi_si 86016 0
xhci_pci_renesas 20480 1 xhci_pci
nvme_auth 28672 1 nvme_core
wmi 32768 0
ipmi_devintf 16384 0
ipmi_msghandler 94208 3 ipmi_devintf,ipmi_si,ipmi_ssif
pinctrl_emmitsburg 20480 0
aesni_intel 356352 0
crypto_simd 16384 1 aesni_intel
cryptd 28672 2 crypto_simd,ghash_clmulni_intel
Running command ['find', '/lib/modules/6.8.0-31-generic/kernel/drivers/md'] with allowed return codes [0, 1] (capture=True)
available md modules:
/lib/modules/6.8.0-31-generic/kernel/drivers/md/raid456.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/raid10.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/raid1.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/raid0.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/persistent-data
/lib/modules/6.8.0-31-generic/kernel/drivers/md/persistent-data/dm-persistent-data.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/md-cluster.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-zoned.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-zero.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-writecache.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-verity.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-unstripe.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-thin-pool.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-switch.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-snapshot.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-service-time.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-round-robin.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-region-hash.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-raid.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-queue-length.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-multipath.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-mirror.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-log.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-log-writes.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-log-userspace.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-io-affinity.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-integrity.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-historical-service-time.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-flakey.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-era.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-ebs.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-delay.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-crypt.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-clone.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-cache.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-cache-smq.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-bufio.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/dm-bio-prison.ko.zst
/lib/modules/6.8.0-31-generic/kernel/drivers/md/bcache
/lib/modules/6.8.0-31-generic/kernel/drivers/md/bcache/bcache.ko.zst
devname '/dev/nvme0n1' had holders: []
Device /dev/nvme0n1 has holders: []
devname '/dev/nvme1n1' had holders: []
Device /dev/nvme1n1 has holders: []
devname '/dev/nvme2n1' had holders: []
Device /dev/nvme2n1 has holders: []
An error occured handling 'md0': ProcessExecutionError - Unexpected error while running command.
Command: ['mdadm', '--create', '/dev/md0', '--run', '--homehost=R660-solid-bengal', '--raid-devices=3', '--metadata=default', '--level=0', '/dev/nvme0n1', '/dev/nvme1n1', '/dev/nvme2n1']
Exit code: -6
Reason: -
Stdout: ''
Stderr: *** buffer overflow detected ***: terminated
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: FAIL: configuring raid: md0
TIMED BLOCK_META: 4.057
finish: cmd-install/stage-partitioning/builtin/cmd-block-meta: FAIL: curtin command block-meta
File "/curtin/curtin/commands/main.py", line 202, in main
ret = args.func(args)
File "/curtin/curtin/log.py", line 97, in wrapper
return log_time("TIMED %s: " % msg, func, *args, **kwargs)
File "/curtin/curtin/log.py", line 79, in log_time
return func(*args, **kwargs)
File "/curtin/curtin/commands/block_meta.py", line 117, in block_meta
return meta_custom(args)
File "/curtin/curtin/commands/block_meta.py", line 2057, in meta_custom
handler(command, storage_config_dict, command_handlers)
File "/curtin/curtin/commands/block_meta.py", line 1645, in raid_handler
mdadm.mdadm_create(md_devname, raidlevel,
File "/curtin/curtin/block/mdadm.py", line 210, in mdadm_create
util.subp(cmd, capture=True)
File "/curtin/curtin/util.py", line 275, in subp
return _subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 139, in _subp
raise ProcessExecutionError(stdout=out, stderr=err,
Exit code: -6
Reason: -
Stdout: ''
Exit code: -6
Reason: -
Stdout: ''
Stderr: ‘’
