| Since | Removed |
| 2.8.0 | 2.9.0 |
This notice is raised when the MAAS snap is configured in all mode, that is, it also runs the PostgreSQL database server inside the snap.
When setting up the MAAS snap via maas init, one of the available modes has traditionally been all. This install mode uses a PostgreSQL server, exclusively for MAAS, inside the snap itself. While this is a great quick-start configuration for small installations and test rigs, it doesn’t provide features needed for production systems, like database replication. Without these features, the scalability and availability of a MAAS installation is severely constrained. For this reason, we’ve deprecated the use of PostgreSQL inside the MAAS snap, and we provide some alternative means to install and configure MAAS – along with tools to migrate current installations.
When setting up the maas snap via maas init, one of the available modes is all. This install mode uses a PostgreSQL server – exclusively for MAAS – inside the snap itself.
While this is a great quick-start configuration for small installations and test rigs, it doesn’t provide features needed for production systems, like database replication. Without these features the scalability of a MAAS installation is severely constrained.
For this reason, we’re deprecating the use of PostgreSQL inside the snap, and providing some helper scripts to set up PostgreSQL for use with MAAS. We’re also providing tools to help migrate current installations. Basically, we’re replacing the all mode with region+rack. In this configuration, the region controller connects to an external database over the network.
Installing MAAS with local PostgreSQL
After installing the maas snap, you can set up PostgreSQL – even if it’s running on a different machine – with the following procedure:
You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
sudo apt update -y sudo apt install -y postgresql -
You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where
$MAAS_DBUSERis your desired database username, and$MAAS_DBPASSis the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'" -
Create the MAAS database with the following command, where
$MAAS_DBNAMEis your desired name for the MAAS database (typically known asmaas). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME" -
Edit
/etc/postgresql/10/main/pg_hba.confand add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than0/0.host $MAAS_DBNAME $MAAS_DBUSER 0/0 md5 -
You can then initialise MAAS via the following command:
Migrating an existing snap install
The migration script will automatically adjust the snap configuration to use the new database. However, note that the target database must be at least the same version as the one currently used in the snap (PostgreSQL 10). Consequently, the migration script only supports Ubuntu 18.04 (bionic) or later.
sudo snap stop maas
sudo -u postgres \
host maasdb maas 0/0 md5
Be sure to replace 0/0, above, with the proper CIDR to restrict acccess to a specific subnet. Finally, you can import the database dump with:
- update the database config in
/var/snap/maas/current/regiond.confwith the properdatabase_hostanddatabase_pass - change the content of
/var/snap/maas/common/snap_modefromalltoregion+rack
