I’m performing server deployments and I’m being limited to 16 simultaneous servers, when this limit is exceeded, the server cannot receive the IP by MAAS pxe.
I couldn’t find an option to increase this limit.
Any tips or information to resolve this limitation?
MAAS : 3.2.7
I’m deploying the servers.
Servers already commissioned and tested.
Yes. They are on the same subnet and vlan.
As I had a demand to activate 300 servers, I am having to execute the process with only 16 simultaneous servers being started in the deploy so that the maas pxe does not present an error in the delivery of the IP.
Searching about , I found information that in other versions there was an option max_concurrent_deployment_threads
Would you have this option in this version and if it would be something realied to it
Has anything ever happened with this? I recently updated to 3.5.6 and now I can only serve 5 bare metal machines at one time. I cannot find a way to increase this. I used to be able to do 9 or more but now we’re stuck.
