About release management
Release management involves everything required to make a release available to external users. This work includes a mix of automation, manual activites, verification, and a good bit of waiting. Also, RC releases and final releases each have some specific, unique complications, which are covered toward the end this document.
And, on top of that, there are lots of little “gotchas” that will make things work weird, until you know to do them. We’ll try to catch as much of that as we can.
In your MAAS repo, under the utilities
directory, you will find a script named release-status
. In most cases, this script will lead you through the steps you need to execute to build a release; however, you may need to get through the first few steps in this process before release-status
becomes useful.
How to create a MAAS release
To produce a MAAS release, you’ll need to either execute the steps in this section or get someone to do them for you. Generally, you only need help if you don’t have the required access (true for very few of these steps), so you’d need to get someone on the MAAS core team to do them for you.
This section will tell you:
- How to create repositories.
- How to check system tests.
- How to version a release.
- How to make a build container.
- How to create a development environment.
- How to build the release.
- How to upload to the test PPA
- How to upload the PPA.
- How to confirm the snap build.
- How to create a milestone for the release.
- How to mark closed bugs as released.
- How to post a release.
This section gives a generic procedure for releasing MAAS. Note that there are unique complications for both RC releases and final releases, so be sure to consult the reference sections at the end of this document.
When publishing a major release for the first time, create the appropriate repositories:
Create a PPA on the MAAS launchpad page:
– If you’re publishing Beta releases, you’ll want to use a PPA named “x.y-next” (e.g., “3.1-next”), with a descriptive name of “MAAS x.y test builds” (e.g., “MAAS 3.1 test builds”).
– If you’re publishing a final release, you’ll want to use a PPA named “x.y” (e.g., “3.1”), with a descriptive name of “MAAS 3.0.” -
Create a test PPA on your personal launchpad page; this will be used to test your builds before pushing them up to a public PPA.
Copy additional dependencies from the PPA of the previous major release to this new PPAs:
– Go to the latest deps page.
– Select “View package details” in the upper right to get here.
– Towards the mid-upper right, select “Copy packages”.
– Under “Packages”, in the right middle of the screen, select the correct OS series and click “Filter”.
– On the screen that comes up, select the checkboxes next to all of the available packages.
– Just below this list, select the Destination PPA to be each of those you have created above, in turn.
– Below this, you can select either “Build the copied sources” or “Copy existing binaries”. In most cases, “copy existing binaries” should work fine.
– Click “Copy packages” and make sure that the results confirm the copy; if not, fix the issue and try again. -
Request a new track on the snap store for the
maas
snap:
– Go to the snapstore discourse forum.
– If you’re not signed up, you’ll need to do that, first (FYI, there’s a confirmation step associated with sign up).
– Request the new track with a message similar to this one, minus the middle paragraph about requesting 2.10 last week. Be sure to include the two bullet points about the snap IDs, and set the tag tostore-requests
– If you’re a new snapcraft forum user, you’ll need to turn the links in the two ID bullet points into literals by surrounding them with backticks, as you will have limited ability to post links.
– Pay attention to the forum for a response. It may take some time, in some cases.
– Make sure that the maas-test-db snap uses (1) the same base as the maas snap, and (2) the latest Postgres version for that base.
[note]
Getting a new track on the snap store is a long-lead-time item; be sure to request it well in advance of your planned first release date.
Both of these tests are scanning master
, so if you’re starting from there, you really want both of these to be green at this moment:
– Check http://maas-integration-ci.internal:8080/job/maas-system-tests/ (for deb)
– Check http://maas-integration-ci.internal:8080/job/maas-system-tests-snap/ (for snap)
If you’re releasing a Beta, it’s worthwhile to find out why the tests are failing, e.g., “Is there some retooling going on which is causing the tests to fail, even though the code is fine?” You may be able to move forward anyway.
Before going further, you must make sure that the system tests pass for the revision you’re planning on releasing, for both the normal and -ea
variant.
Run the maas-tag-release jenkins job to update the MAAS version.
- Login to Jenkins at that URL
- Click
Build with parameters
- Enter the details, paying particular attention to the version
This step will leave you a new commit in the MAAS master branch, versioned with the new release identifier.
Some important notes:
- The version should use the format ..(a|b|rc). For example, 3.1.0-Beta 2 would be labeled as “3.1.0b2” when tagging the release.
- The DEBFULLNAME
should be e.g. Joe Bloggs, and DEBEMAIL
e.g. joe.bloggs@canonical.com
- There must be a GPG key registered in Launchpad that’s associated with the DEBFULLNAME
and DEBEMAIL
that you enter.
- Note that you cannot have a comment associated with your GPG key, as this will sometimes cause the signing tool to fail when building the release later.
Create the build container
Run the following script – from the directory containing your MAAS git repo (but not the repo itself) – to automate creation of a build container:
#!/bin/bash
set -e
SRC=$(readlink -f "${1:-$PWD}")
if [ ! -d "$SRC" ]; then {
echo "Expected '$1' to be a directory" >&2
exit 1
fi
PROJECT_NAME=$(basename "$SRC")
CONTAINER_NAME=${CONTAINER:-$PROJECT_NAME}
SSH_ME=${SSH_ME:-$(bzr lp-login)}
SERIES=${SERIES:-focal}
# TODO: Conditionalise launching and setup based on existing or not
# lxc list --fast --format=json "$PROJECT_NAME" | grep -q "$PROJECT_NAME"
lxc launch --verbose --debug ubuntu:$SERIES "$CONTAINER_NAME" -c raw.idmap="both $UID 1000" -c user.user-data="\
#cloud-config
{'ssh_import_id': '$SSH_ME', 'apt_pipelining': 'os', 'package_update': true,
'packages': ['language-pack-en'], 'write-files': {'content': 'export DEBEMAIL=\"Adam Collard <adam.collard@canonical.com>\"', 'path': '/home/ubuntu/.bashrc', 'append': 'true'}
lxc exec "$CONTAINER_NAME" -- cloud-init status --wait || echo 'Old cloud-init, snoozing instead'; sleep 5
[ -f ~/.gitconfig ] && lxc file push ~/.gitconfig "$CONTAINER_NAME"/home/ubuntu/.gitconfig
if host "$CONTAINER_NAME".lxd >/dev/null; then
DST="$CONTAINER_NAME".lxd
else
DST=$(lxc list "$CONTAINER_NAME" -c4 --format=csv | cut -d' ' -f1)
fi
ssh-keyscan -H $DST >> ~/.ssh/known_hosts 2>/dev/null
lxc config device add "$CONTAINER_NAME" "${PROJECT_NAME}-src" disk source="$SRC" path=/home/ubuntu/"$PROJECT_NAME"
echo "$CONTAINER_NAME ready to hack on; try
ssh ubuntu@$DST"
To run this script successfully, you’ll need to use an invocation something like this:
SERIES=<os-series-name> CONTAINER=<memorable-name> SSH_ME=<your-launchpad-ssh-id> hack-on
As an example only:
SERIES=focal CONTAINER=maas SSH_ME=billwear hack-on
Mount your gnupg directory
When the container is ready, you’ll also want to bind mount
your ~/.gnupg
directory, containing the key set you want to use to sign the release, to the container, like this:
lxc config device add maas gnupg-home disk source=/home/$USERNAME/.gnupg/ path=/home/ubuntu/.gnupg
Load your ssh directory
You might also want to copy the contents of your SSH keys to the container – excluding the authorized keys file – so that you can access git.launchpad.net
easily.
Checkout your versioned commit
Note that your MAAS repo will be mounted automatically into the container as part of the hack-on
process. You want to update that repo to the version you just committed with the Jenkins script.
Depending on whether you’ve built MAAS before, you may or may not have all the development tools you’ll need.
How to download the build tools
You’ll may want to run the command:
apt install build-essential
before you attempt to go any further; otherwise, you won’t have all the tools you need to build.
How to download the dependencies you’ll need
As with most build processes, you may need to install the source dependencies with a command like this:
make install-dependencies
Note that there’s a hiccup point during the installation of snapd
, so you may hang for some time on this line:
if [ -x /usr/bin/snap ]; then cat required-packages/snaps | xargs -L1 sudo snap install; fi
It may even fail once or twice, depending on your internet connection, the phases of the moon, or what you had for dinner last night. Just try again.
Dealing with other missing packages
You may have to install one or more other packages as you go. Pay close attention to any errors: When the build fails, try entering the missing command to find out what package you need sudo apt install...
to get going again. This may happen three or four times. This is normal, but pay attention.
Building the release is fairly straightforward:
utilities/release-build $ubuntu_release
where $ubuntu_release
is the series you’re building, e.g., focal.
Here are some important hints for the build:
- Make sure that DEBFULLNAME and DEBEMAIL variables are set to the right values for the debian package, e.g., the name and e-mail that matches the GPG key of the person who is building the release. If you think you may be in and out of your build container (likely), it’s probably best to set these two variables in your
.bashrc
file for theubuntu
user:
export DEBFULLNAME="your gpg full name"
export DEBEMAIL="your gpg email"
Make sure that you export them.
Note that you can’t run the build in an
su
'd session: GPG has a bug that will cause the signing part to fail at the end; e.g., you can’t log on asroot
and thensu -
to your account – you have to sign on directly as the account that owns the correct GPG key, or theubuntu
account, if you’re using thehack-on
script above. -
It is instinctive to set the
$ubuntu_release
to the MAAS release if you’re in a hurry. If theutilities/release-build $ubuntu_release
returns a cryptic error like this one:
Unsupported distro: 2.8.7
then you should go back and set $ubuntu_release
to the actual OS series, such as “bionic” or “focal.”
- There are two or three places where you may bomb out if your internet connection hiccups at the wrong time. These generally involve URLs. If this happens, just try it again; eventually, you will get all the way through the build.
Upload the packages built in the previous step to the PPA, using the following script:
utilities/release-upload <PPA> <changes file>
Set the as follows:
- When uploading a stable release (whether a final or a point release), a stable ppa:maas/M.m PPA should be used:
utilities/release-upload ppa:maas/2.X build_pkg/maas_2.X.*.changes
The stable PPA can also be used for preleases of a M.m.0 release, since there’s no stable release for that major at this point
- When uploading a pre-release for a point release (e.g. M.m.1-rc1), a testing ppa:maas/M.m-next PPA should be used:
utilities/release-upload ppa:maas/2.X-next build_pkg/maas_2.X.*.changes
- When Launchpad has finished the build, release it to the PPA.
How??
Confirm the snap builds, by following this procedure:
How??
n. When the snaps are built, release them to the right risk channel.
How to create a new milestone
Create a new, active milestone for the next release (after this one), to target bugs that weren’t completed for this release:
We manually tag a release in git once the release has been built and published. To do so run the following in the maas repo:
git checkout $RELEASED_COMMIT
git tag $RELEASE_VERSION
git push --tags
How??
Use bin/release-manage in maas-release-tools to mark closed bugs as released:
bin/release-manage maas move-done-bugs next $milestone
bin/release-manage maas release-milestone $milestone
Also, create a release for the milestone on LP, with the following procedure:
How??
How to post a final release
If this is a final release, you should also complete the following steps:
Post the release notes to discourse (or see that they are posted, if this is the normal responsibility of another teammate).
Post an announcment in discourse, or see that one is posted.
Switch the default snap track to the new release by:
How??
There are other complications for a final release, as shown below.
How to push the MAAS test DB to the new snap track
When starting a new major release, you should update or push the maas-test-db
snap to the new track, with the following procedure:
How??
RC release reference
When an RC has been released, a new branch should be created, and build scripts should be updated to use the new branch. The following procedures are necessary:
Use the update-release-branch job to cut the new branch, following the
<Major version>.<Minor version>
naming scheme -
Ask the design team to branch maas-ui
Ask @billwear to branch lp:maas-offline-docs
Point the maas-ui and lp:maas-offline-docs git submodules in lp:maas to the M.m branch:
cd maas/src/maas-offline-docs/src
git pull
git checkout M.m
maas/src/maasui/src
git pull
git checkout M.m
- Commit the changes:
git commit src/maas-offline-docs/src src/maasui/src -m "Switch docs and UI to M.m branch"
change the MAAS_PPA value in Makefile to the release PPA (e.g. ppa:maas/M.m)
Set the Source: for the Snap builds to the branch you just created when building the Snap with Launchpad.
Release snap builds to candidate channel (and close beta).
Final release reference
On final releases of a new major, some extra steps are required:
- Release snap builds to the stable channel (and close candidate).
- Release maas-test-db to the stable channel (and close candidate).
- Switch default tracks for both maas and maas-test-db to the new version.
Troubleshooting reference
If a Snap fails to build due to a proxy error you can use the LaunchPad API to request a rebuild:
- Start the LaunchPad shell with lp-shell production devel
- To rebuild arm64 and ppc64el (for example), you would do:
snap = lp.load('/~maas-committers/+snap/maas-2.9')
for arch in ('arm64', 'ppc64el'):
snap.requestBuild(archive=snap.auto_build_archive, distro_arch_series='/ubuntu/focal/%s' % arch, pocket=snap.auto_build_pocket, channels={"snapcraft": "stable"})
