I have an issue with machines not loading into MAAS and not commissioning. I followed the installation documents, got the server functional, and I can get my test devices to PXE boot from the MAAS server. However they never show up in the device listing. When I manually add them they just fail on commissioning. I would appreciate some advice here on this.
| Mon, 03 Nov. 2025 19:44:01 | Node changed status - From ‘Commissioning’ to ‘Failed commissioning’ |
| Mon, 03 Nov. 2025 19:44:01 | Marking node failed - Node operation ‘Commissioning’ timed out after 30 minutes. |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-ssh with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-update_etc_hosts with frequency always |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-mounts with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-growpart with frequency always |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-set_passwords with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-users_groups with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-set_hostname with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-resizefs with frequency always |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-update_hostname with frequency always |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-seed_random with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:15 | Node commissioning - ‘cloudinit’ running config-rsyslog with frequency once-per-instance |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ reading and applying vendor-data2 |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ reading and applying user-data |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ reading and applying vendor-data |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ setting up datasource |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ activating datasource |
| Mon, 03 Nov. 2025 19:14:14 | Node commissioning - ‘cloudinit’ attempting to read from cache [trust] |
| Mon, 03 Nov. 2025 19:14:13 | Node commissioning - ‘cloudinit’ searching for local data from DataSourceMAASLocal |
| Mon, 03 Nov. 2025 19:14:13 | Node commissioning - ‘cloudinit’ attempting to read from cache [check] |
| Mon, 03 Nov. 2025 19:14:13 | Gathering information |
| Mon, 03 Nov. 2025 19:13:39 | HTTP Request - /images/fa185d1/ubuntu/amd64/ga-24.04/noble/stable/boot-initrd |
| Mon, 03 Nov. 2025 19:13:38 | HTTP Request - /images/ad75be1/ubuntu/amd64/ga-24.04/noble/stable/boot-kernel |
| Mon, 03 Nov. 2025 19:13:38 | Performing PXE boot |
