Hey guys
I have had a working setup with version of MaaS 2.4 running for some time, but I had to change hard drive on the master, so I decided for a fresh install and to upgrade to version 2.6.
Download and installation went fine and as expected. However, now when I turn the workers on they can’t find MaaS, so they can’t do a PXE boot.
I remember having a similar issue when I installed MaaS 2.4 in the first place. Back then I figured out that MaaS only worked if fabric-0
was on the network interface that connects to the switch that the worker machines was on. Right now I can’t figure out how to change, which interface is connected to which fabric.
Is correct that MaaS only broadcast on fabric-0
? And how can I solve this?
On the master I have the following interfaces:
Name - IP - FABRIC - DHCP
enp3s0
- 10.10.8.250
- fabric-0
- DHCP not enabled
eno1
- 192.168.200.1
- fabric-2
- DHCP enabled
The worker machines are sitting on the 192.168.200.0
network.
From the master I can scan the network and see that the workers indeed comes on and gets a 192.168.200.X
ip.
Thanks in advance!
