Hello Everyone,
I hope your doing fine.
After a fresh MaaS snap 3.4 Beta 3 install, region+rack, I cannot telnet port 123 for NTP from nowhere even if :
ps -ZyAlf | grep -i -e ntp -e chrony
- S root 969 703 0 80 0 4004 2656 - 16:37 ? 00:00:00 /snap/maas/x1/usr/sbin/chronyd -u root -d -f /var/snap/maas/x1/etc/chrony/chrony.conf
sudo tail -f /var/snap/maas/common/log/chrony.log
2023-09-26T16:37:51Z chronyd version 4.2 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 -DEBUG)
2023-09-26T16:37:51Z Could not open keyfile /var/snap/maas/current/etc/chrony/chrony.keys
2023-09-26T16:37:51Z Running with root privileges
2023-09-26T16:37:51Z Frequency 0.000 +/- 1000000.000 ppm read from /var/snap/maas/common/chrony/chrony.drift
cat /var/snap/maas/x1/etc/chrony/chrony.conf
# Welcome to the chrony configuration file. See chrony.conf(5) for more
# information about usuable directives.
# Use servers from the NTP Pool Project. Approved by Ubuntu Technical Board
# on 2011-02-08 (LP: #104525). See http://www.pool.ntp.org/join.html for
# more information.
# pool 0.ubuntu.pool.ntp.org iburst # Disabled by MAAS.
# pool 1.ubuntu.pool.ntp.org iburst # Disabled by MAAS.
# pool 2.ubuntu.pool.ntp.org iburst # Disabled by MAAS.
# pool 3.ubuntu.pool.ntp.org iburst # Disabled by MAAS.
# Use Ubuntu's ntp server as a fallback.
# pool ntp.ubuntu.com # Disabled by MAAS.
# This directive specify the location of the file containing ID/key pairs for
# NTP authentication.
# This directive specify the file into which chronyd will store the rate
# information.
driftfile /var/snap/maas/common/chrony/chrony.drift
# Uncomment the following line to turn logging on.
#log tracking measurements statistics
# Log files location.
logdir /var/snap/maas/common/log/chrony
pidfile /var/snap/maas/current/run/chronyd.pid
dumpdir /var/snap/maas/current/run
bindcmdaddress /var/snap/maas/current/run/chronyd.sock
# Stop bad estimates upsetting machine clock.
maxupdateskew 100.0
# This directive enables kernel synchronisation (every 11 minutes) of the
# real-time clock. Note that it can’t be used along with the 'rtcfile' directive.
rtcsync
# Step the system clock instead of slewing it if the adjustment is larger than
# one second, but only in the first three clock updates.
makestep 1 3
include /var/snap/maas/x1/etc/chrony/maas.conf
cat /var/snap/maas/x1/etc/chrony/maas.conf
# MAAS NTP configuration.
hwtimestamp *
local stratum 8 orphan
allow
Any advices on how to debug the issue ?
Thanks in advance,
Best Regards,
Mickaël.
