One of the key elements of managing machines is configuring and managing their storage space. This subsection will help you learn:
- About block devices
- About partitions
- About storage restrictions
- About VMFS datastores
- About UEFI booting
- About final storage modifications
The Storage tab on the machine list brings up a form that allows you to view/edit the file system, partitioning and storage parameters for the selected machine:
This tab describes the filesystem(s) in use, as well as the available and used partitions for this machine.
About block devices
Physical
Virtual
About partitions
- An EFI partition is required to be on the boot disk for UEFI.
- You cannot place partitions on logical volumes.
- You cannot use a logical volume as a Bcache backing device.
About UEFI booting
UEFI must be enabled or disabled for the lifespan of the machine. For example, do not enlist a machine with UEFI enabled, and then disable it before commissioning. It won’t work!
About disk erasure
Disk erasure pertains to the erasing of data on each of a machine’s disks when the machine has been released (see Release action) back into the pool of available machines. The user can choose from among three erasure types before confirming the Release action, and a default erasure configuration can also be set. This section will help you learn:
- About disk erasure types
- About standard erasure
- About secure erasure
- About quick erasure
- About erasure order of preference
- Standard erasure
- Secure erasure
- Quick erasure
About quick erasure
If all three options are checked when the machine is released, the following order of preference is applied:
- Use ‘secure erase’ if the disk supports it
- If it does not, then use ‘quick erase’
