I’ve got Maas working with vlans and I’m able to create pods. What I want to know is, how to make a maas that can deploy to it’s self as well as other nodes/pods.
What I’ve tried:
manually editing netplan to no effect, I’m just not getting netplan! I’ve not found documentation that really explains things. I miss the old network interfaces way!
I’ve manually configured a maas node before deploying it as a KVM host.
So here is a question for the above approach:
Should I create all the networking interface then add the vlans then bridge to the vlan?
Should I create a bridge to the networking interface then add the vlans?
Something else?
What’s the best practice here?
In the end I will have a MaaS host that ill see it’s self as a pod, be able to deploy to it’s self(juju) as well as deploy to other physical nodes.
I’ve seen this “https://github.com/pmatulis/maas-one” I was unable to figure out how to modify it to my needs. It can deploy to it’s self but I was unable to figure out bridging, rather than NAT.
Thank you for your time.
