I am using MAAS 3.5.3-16341-g.7adb035d6-0ubuntu1~22.04.1 (installed w/apt) on an up-to-date Ubuntu 22.04 LTS, and seemingly running into the problem reported here.
I am successfully able to get my libvirt VM to PXE boot with MAAS, but when setting up Power Type to virsh prior to Commissioning, I run into the problem described here.
My connection URL is
qemu+ssh://root@10.61.60.2/system
which is what I use with my local virt-manager (desktop Linux) to connect to 10.61.60.2 (remote server/KVM host).
and the Virsh VM is the UUID I pulled from the VM element <uuid>......</uuid>
MAAS logging ends up in the journalctl facility on my host, and in paging through the results for the following two invocations, I see no errors:
The following is what I have pulled out of journalctl on 10.61.60.2:
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: maasserver.websockets.handlers.machine: [critical] Failed to update power state of machine.
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: Traceback (most recent call last):
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1750, in gotResult
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: current_context.run(_inlineCallbacks, r, gen, status)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1740, in _inlineCallbacks
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: status.deferred.errback()
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 700, in errback
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: self._startRunCallbacks(fail)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 763, in _startRunCallbacks
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: self._runCallbacks()
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: --- <exception caught here> ---
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 857, in _runCallbacks
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: current.result = callback( # type: ignore[misc]
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/maasserver/websockets/handlers/machine.py", line 1256, in eb_unknown
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: failure.trap(UnknownPowerType, NotImplementedError)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/python/failure.py", line 451, in trap
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: self.raiseException()
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/python/failure.py", line 475, in raiseException
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: raise self.value.with_traceback(self.tb)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/internet/defer.py", line 1656, in _inlineCallbacks
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: result = current_context.run(
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/twisted/python/failure.py", line 489, in throwExceptionIntoGenerator
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: return g.throw(self.type, self.value, self.tb)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: File "/usr/lib/python3/dist-packages/maasserver/models/node.py", line 6161, in exec_power_workflow
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: raise PowerActionFail(cause)
Feb 24 15:39:56 kumo-x-maas-1 regiond[117504]: provisioningserver.rpc.exceptions.PowerActionFail: ExitError: exit status 1
