Hello.
I have a bunch of servers using RedFish with no standard username and password. Normally, in the Machines Configuration section, I’d normally have:
Power configuration
Power type Redfish
Redfish address 10...*
Redfish user USERID
Redfish password ********
Node ID
I just powered on that node and spot in the console that the commission has started (luckily I did not have any data on that node), with a bizarrely looking Machine Configuration section already populated:
Power configuration
Power type IPMI
Power driver LAN_2_0 [IPMI 2.0]
Power boot type EFI boot
IP address10...*
Power user maas
Power password ***************
K_g BMC key —
Cipher Suite ID 3 - HMAC-SHA1::****
Privilege Level Administrator
Workaround Flags Opensesspriv
Power MAC ****
Power off mode Power off
How would it get all those details from and successfully have control over IPMI interface? Is this some part of RedShift framework?
Also, is the act of commissioning actually destroying anything on the node’s storage or this is only like running a live-CD to gather all the details about the server?
Cheers.
