I’m trying to do the following for a week with no luck! I’d like to create a MACVLAN during machine deployment process. I’ve already provided a code for this process using Cloud-Init syntax:
#cloud-config
write_files:
- content: |
#!/bin/bash
sudo ip link add eth0 link enp0s3 type macvlan mode bridge
sudo ifconfig eth0 up
path: /tmp/macvlan.sh
permissions: '777'
- content: |
[Unit]
Description=macvlan setup service
[Service]
ExecStart=/etc/init.d/macvlan.sh
[Install]
WantedBy=multi-user.target
path: /tmp/macvlan.service
permissions: '777'
runcmd:
- sudo mv /tmp/macvlan.sh /etc/init.d/macvlan.sh
- sudo mv /tmp/macvlan.service /etc/systemd/system/macvlan.service
- systemctl enable macvlan
- systemctl start macvlan
So now I’d like to know how to use this code automatically during deployment process ? I know there is a way to manually use the code as the following:
maas $PROFILE machine deploy $SYSTEM_ID user_data=$(base64 ./import_key.sh)
But I want the MaaS to do it for all machines automatically (because I’m using Juju controller to deploy new machines and I can’t do it manually). If it is not possible to use Cloud-Init then is it possible to use Curtin? How?
