Hello everyone, I have 2 MAAS servers in HA mode. However, both can resolve the PTR records but A not. In UI A records are present but I cannot find anything but apra in actual config files for bind9.
Here is a screenshot: https://imgur.com/a/T2jjsqQ
MAAS versions (installed via snap) are: 3.0/stable: 3.0.0-10029-g.986ea3e45 2021-06-22 (15003) 141MB -
Hi @mihail-igoshin, in the screenshot, what is the record in question? Have you seen any errors in the maas.log while making a DNS update? Could you provide the bind9 config file as well?
Hi, the issue was that MAAS was unable to resolve A records for a specific domains but did PRT records. It issue was that Authoritative was disabled for domain. So everything is fine now.
thanks for the awesome information.
