MAAS UI not working anymore
Hello
I am having an issue with MAAS
The UI is not starting anymore and some pebble services are down:
pebble services
Service Startup Current Since
agent disabled inactive -
apiserver enabled active yesterday at 09:34 UTC
bind9 disabled active yesterday at 09:35 UTC
dhcpd disabled inactive -
dhcpd6 disabled inactive -
http disabled inactive -
ntp disabled active yesterday at 09:34 UTC
proxy disabled active yesterday at 09:35 UTC
rackd enabled backoff today at 08:57 UTC
regiond enabled active yesterday at 09:34 UTC
syslog disabled active yesterday at 09:35 UTC
temporal disabled active yesterday at 09:34 UTC
temporal-worker disabled active yesterday at 09:34 UTC
I’ve tried to start the http but nothing
pebble start http
2025-10-21T08:58:26Z INFO Most recent service output:
error: cannot perform the following tasks:
  • Start service “http” (cannot start service: exited quickly with code 1)
I would need some help please
Many thanks
Have you checked the logs?
I don’t know how to check logs for MAAS.
MAAS version is 3.6.2. OS - Ubuntu Server 22.04.5
In /var/log/syslog I have this:
$ tail -200 /var/log/syslog
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 waiter.callback(value)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 877, in callback
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 self._startRunCallbacks(result)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 984, in _startRunCallbacks
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 self._runCallbacks()
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011— —
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1078, in _runCallbacks
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 current.result = callback( # type: ignore[misc]
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/maasserver/ipc.py”, line 714, in
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 lambda protocol: protocol.callRemote(
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 950, in callRemote
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 return co._doCommand(self)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 1973, in _doCommand
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 self.makeArguments(self.structured, proto),
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 1887, in makeArguments
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 return _objectsToStrings(objects, cls.arguments, cls.commandType(), proto)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 2718, in _objectsToStrings
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 argparser.toBox(argname, strings, myObjects, proto)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 1396, in toBox
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 strings[name] = self.toStringProto(obj, proto)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 1421, in toStringProto
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 return self.toString(inObject)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/protocols/amp.py”, line 1456, in toString
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011 return b"%d" % (inObject,)
Oct 21 12:34:32 maassrv maas-regiond[87983]: #011builtins.TypeError: %d format: a real number is required, not NoneType
Oct 21 12:34:32 maassrv maas-log[88060]: maas.bootsources: [info] Updated boot sources cache.
Oct 21 12:34:32 maassrv maas-log[88060]: maas.bootresources: [info] Started importing of boot images from 1 source(s).
Oct 21 12:34:32 maassrv maas-log[88060]: maas.import-images: [info] Downloading image descriptions from Index of /ephemeral-v3/stable
Oct 21 12:34:32 maassrv maas-log[88060]: maas.import-images: [info] Region downloading image descriptions from ‘Index of /ephemeral-v3/stable’.
Oct 21 12:34:33 maassrv maas-log[88060]: maas.import-images: [warn] Ignoring unsupported product com.ubuntu.maas.stable:1:pxelinux:pxe:amd64
Oct 21 12:34:33 maassrv maas-regiond[87983]: maasserver.listener: [info] Listening for database notifications.
Oct 21 12:34:34 maassrv maas-log[88060]: maas.bootresources: [info] Importing images from source: Index of /ephemeral-v3/stable
Oct 21 12:34:35 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:ga-22.04 20250911
Oct 21 12:34:35 maassrv maas.pebble[5435]: 2025-10-21T12:34:35.790Z [pebble] Service “rackd” starting: sh -c “exec systemd-cat -t maas-rackd $SNAP/bin/run-rackd”
Oct 21 12:34:35 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:ga-22.04-lowlatency 20250911
Oct 21 12:34:35 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:hwe-22.04 20250911
Oct 21 12:34:36 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:hwe-22.04-edge 20250911
Oct 21 12:34:36 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:hwe-22.04-lowlatency 20250911
Oct 21 12:34:36 maassrv maas-log[88060]: maas.bootresources: [warn] Ignoring unsupported filetype(manifest) from com.ubuntu.maas.stable:v3:boot:22.04:amd64:hwe-22.04-lowlatency-edge 20250911
Oct 21 12:34:36 maassrv maas-regiond[87983]: maasserver.bootresources: [info] Boot Resources synchronisation has completed
Oct 21 12:34:36 maassrv maas-log[88060]: maas.bootresources: [info] Finished importing of boot images from 1 source(s).
Oct 21 12:34:36 maassrv kernel: [100835.080964] audit: type=1326 audit(1761050076.436:6524): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88314 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7fccc9dca25d code=0x50000
Oct 21 12:34:36 maassrv kernel: [100835.080973] audit: type=1326 audit(1761050076.436:6525): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88314 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7fccc9dca25d code=0x50000
Oct 21 12:34:37 maassrv maas-rackd[88314]: Traceback (most recent call last):
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/bin/rackd”, line 8, in
Oct 21 12:34:37 maassrv maas-rackd[88314]: sys.exit(run())
Oct 21 12:34:37 maassrv maas-rackd[88314]: ^^^^^
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/server.py”, line 95, in run
Oct 21 12:34:37 maassrv maas-rackd[88314]: runService(“maas-rackd”)
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/server.py”, line 90, in runService
Oct 21 12:34:37 maassrv maas-rackd[88314]: UnixApplicationRunner(config).run()
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/application/app.py”, line 370, in run
Oct 21 12:34:37 maassrv maas-rackd[88314]: self.application = self.createOrGetApplication()
Oct 21 12:34:37 maassrv maas-rackd[88314]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/application/app.py”, line 432, in createOrGetApplication
Oct 21 12:34:37 maassrv maas-rackd[88314]: ser = plg.makeService(self.config.subOptions)
Oct 21 12:34:37 maassrv maas-rackd[88314]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 254, in makeService
Oct 21 12:34:37 maassrv maas-rackd[88314]: for service in self._makeServices(
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 194, in _makeServices
Oct 21 12:34:37 maassrv maas-rackd[88314]: yield self._makeHTTPService()
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 56, in _makeHTTPService
Oct 21 12:34:37 maassrv maas-rackd[88314]: s = socket.socket(socket.AF_INET6, socket.SOCK_STREAM)
Oct 21 12:34:37 maassrv maas-rackd[88314]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:34:37 maassrv maas-rackd[88314]: File “/usr/lib/python3.12/socket.py”, line 233, in init
Oct 21 12:34:37 maassrv maas-rackd[88314]: _socket.socket.init(self, family, type, proto, fileno)
Oct 21 12:34:37 maassrv maas-rackd[88314]: OSError: [Errno 97] Address family not supported by protocol
Oct 21 12:34:37 maassrv maas.pebble[5435]: 2025-10-21T12:34:37.733Z [pebble] Service “rackd” stopped unexpectedly with code 1
Oct 21 12:34:37 maassrv maas.pebble[5435]: 2025-10-21T12:34:37.733Z [pebble] Service “rackd” on-failure action is “restart”, waiting ~30s before restart (backoff 2920)
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.208Z [pebble] GET /v1/services?names=bind9 213.306µs 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.208Z [pebble] GET /v1/services?names=ntp 130.724µs 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.208Z [pebble] GET /v1/services?names=temporal 126.984µs 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.209Z [pebble] GET /v1/services?names=syslog 440.866µs 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.209Z [pebble] GET /v1/services?names=temporal-worker 103.596µs 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.209Z [pebble] GET /v1/services?names=http 105.687µs 200
Oct 21 12:34:53 maassrv maas-log[88060]: maas.service_monitor: [info] Service ‘maas-http’ is not on, it will be started.
Oct 21 12:34:53 maassrv maas-regiond[87949]: provisioningserver.utils.services: [critical] Failed to update and/or record network interface configuration: Couldn’t listen on :::5240: [Errno 97] Address family not supported by protocol.; interfaces: {‘enp0s25’: {‘type’: ‘physical’, ‘mac_address’: ‘f0:de:f1:6f:e8:90’, ‘links’: [{‘mode’: ‘static’, ‘address’: ‘192.168.1.3/24’, ‘gateway’: ‘192.168.1.1’}], ‘enabled’: True, ‘parents’: , ‘source’: ‘machine-resources’, ‘monitored’: True}, ‘wlp3s0’: {‘type’: ‘physical’, ‘mac_address’: ‘8c:a9:82:c3:02:8a’, ‘links’: , ‘enabled’: False, ‘parents’: , ‘source’: ‘machine-resources’, ‘monitored’: False}}
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011Traceback (most recent call last):
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2003, in _inlineCallbacks
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 result = context.run(gen.send, result)
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1074, in do_action
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 yield self._updateInterfaces(interfaces)
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2260, in unwindGenerator
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 return _cancellableInlineCallbacks(gen)
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2172, in _cancellableInlineCallbacks
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 _inlineCallbacks(None, gen, status, _copy_context())
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011— —
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1158, in _updateInterfaces
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 self._configureBeaconing(interfaces)
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1440, in _configureBeaconing
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 self.beaconing_protocol = BeaconingSocketProtocol(
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 466, in init
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 self._join_multicast_groups()
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 476, in _join_multicast_groups
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 self.listen_port = self.reactor.listenMulticast(
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/posixbase.py”, line 251, in listenMulticast
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 p.startListening()
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/udp.py”, line 184, in startListening
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 self._bindSocket()
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/udp.py”, line 203, in _bindSocket
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011 raise error.CannotListenError(self.interface, self.port, le)
Oct 21 12:34:53 maassrv maas-regiond[87949]: #011twisted.internet.error.CannotListenError: Couldn’t listen on :::5240: [Errno 97] Address family not supported by protocol.
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.384Z [pebble] POST /v1/services 156.523588ms 202
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.477Z [pebble] GET /v1/services?names=proxy 235.438114ms 200
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.477Z [pebble] Service “http” starting: sh -c “exec systemd-cat -t maas-http $SNAP/bin/run-nginx”
Oct 21 12:34:53 maassrv maas-http[88333]: 2025/10/21 12:34:53 [emerg] 88333#88333: socket() [::]:5248 failed (97: Address family not supported by protocol)
Oct 21 12:34:53 maassrv maas.pebble[5435]: 2025-10-21T12:34:53.581Z [pebble] Change 5541 task (Start service “http”) failed: cannot start service: exited quickly with code 1
Oct 21 12:34:54 maassrv maas-log[88060]: maas.service_monitor: [error] Service ‘reverse_proxy’ failed to start: Pebble change 5541 failed with an error: cannot perform the following tasks:#012- Start service “http” (cannot start service: exited quickly with code 1)
Oct 21 12:35:01 maassrv CRON[88341]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Oct 21 12:35:07 maassrv maas.pebble[5435]: 2025-10-21T12:35:07.758Z [pebble] Service “rackd” starting: sh -c “exec systemd-cat -t maas-rackd $SNAP/bin/run-rackd”
Oct 21 12:35:08 maassrv kernel: [100866.941466] audit: type=1326 audit(1761050108.295:6526): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88343 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7f092a73d25d code=0x50000
Oct 21 12:35:08 maassrv kernel: [100866.941480] audit: type=1326 audit(1761050108.295:6527): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88343 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7f092a73d25d code=0x50000
Oct 21 12:35:09 maassrv maas-rackd[88343]: Traceback (most recent call last):
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/bin/rackd”, line 8, in
Oct 21 12:35:09 maassrv maas-rackd[88343]: sys.exit(run())
Oct 21 12:35:09 maassrv maas-rackd[88343]: ^^^^^
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/server.py”, line 95, in run
Oct 21 12:35:09 maassrv maas-rackd[88343]: runService(“maas-rackd”)
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/server.py”, line 90, in runService
Oct 21 12:35:09 maassrv maas-rackd[88343]: UnixApplicationRunner(config).run()
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/application/app.py”, line 370, in run
Oct 21 12:35:09 maassrv maas-rackd[88343]: self.application = self.createOrGetApplication()
Oct 21 12:35:09 maassrv maas-rackd[88343]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/application/app.py”, line 432, in createOrGetApplication
Oct 21 12:35:09 maassrv maas-rackd[88343]: ser = plg.makeService(self.config.subOptions)
Oct 21 12:35:09 maassrv maas-rackd[88343]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 254, in makeService
Oct 21 12:35:09 maassrv maas-rackd[88343]: for service in self._makeServices(
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 194, in _makeServices
Oct 21 12:35:09 maassrv maas-rackd[88343]: yield self._makeHTTPService()
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/plugin.py”, line 56, in _makeHTTPService
Oct 21 12:35:09 maassrv maas-rackd[88343]: s = socket.socket(socket.AF_INET6, socket.SOCK_STREAM)
Oct 21 12:35:09 maassrv maas-rackd[88343]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Oct 21 12:35:09 maassrv maas-rackd[88343]: File “/usr/lib/python3.12/socket.py”, line 233, in init
Oct 21 12:35:09 maassrv maas-rackd[88343]: _socket.socket.init(self, family, type, proto, fileno)
Oct 21 12:35:09 maassrv maas-rackd[88343]: OSError: [Errno 97] Address family not supported by protocol
Oct 21 12:35:09 maassrv maas.pebble[5435]: 2025-10-21T12:35:09.588Z [pebble] Service “rackd” stopped unexpectedly with code 1
Oct 21 12:35:09 maassrv maas.pebble[5435]: 2025-10-21T12:35:09.589Z [pebble] Service “rackd” on-failure action is “restart”, waiting ~30s before restart (backoff 2921)
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.220Z [pebble] GET /v1/services?names=bind9 116.073µs 200
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.222Z [pebble] GET /v1/services?names=ntp 82.311µs 200
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.222Z [pebble] GET /v1/services?names=syslog 99.545µs 200
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.222Z [pebble] GET /v1/services?names=http 71.484µs 200
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.222Z [pebble] GET /v1/services?names=temporal 84.812µs 200
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.222Z [pebble] GET /v1/services?names=temporal-worker 84.619µs 200
Oct 21 12:35:23 maassrv maas-log[88060]: maas.service_monitor: [info] Service ‘maas-http’ is not on, it will be started.
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.259Z [pebble] GET /v1/services?names=proxy 173.893µs 200
Oct 21 12:35:23 maassrv maas-regiond[87949]: provisioningserver.utils.services: [critical] Failed to update and/or record network interface configuration: Couldn’t listen on :::5240: [Errno 97] Address family not supported by protocol.; interfaces: {‘enp0s25’: {‘type’: ‘physical’, ‘mac_address’: ‘f0:de:f1:6f:e8:90’, ‘links’: [{‘mode’: ‘static’, ‘address’: ‘192.168.1.3/24’, ‘gateway’: ‘192.168.1.1’}], ‘enabled’: True, ‘parents’: , ‘source’: ‘machine-resources’, ‘monitored’: True}, ‘wlp3s0’: {‘type’: ‘physical’, ‘mac_address’: ‘8c:a9:82:c3:02:8a’, ‘links’: , ‘enabled’: False, ‘parents’: , ‘source’: ‘machine-resources’, ‘monitored’: False}}
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011Traceback (most recent call last):
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2003, in _inlineCallbacks
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 result = context.run(gen.send, result)
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1074, in do_action
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 yield self._updateInterfaces(interfaces)
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2260, in unwindGenerator
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 return _cancellableInlineCallbacks(gen)
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 2172, in _cancellableInlineCallbacks
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 _inlineCallbacks(None, gen, status, _copy_context())
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011— —
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1158, in _updateInterfaces
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 self._configureBeaconing(interfaces)
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 1440, in _configureBeaconing
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 self.beaconing_protocol = BeaconingSocketProtocol(
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 466, in init
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 self._join_multicast_groups()
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/lib/python3.12/site-packages/provisioningserver/utils/services.py”, line 476, in _join_multicast_groups
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 self.listen_port = self.reactor.listenMulticast(
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/posixbase.py”, line 251, in listenMulticast
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 p.startListening()
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/udp.py”, line 184, in startListening
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 self._bindSocket()
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 File “/snap/maas/40614/usr/lib/python3/dist-packages/twisted/internet/udp.py”, line 203, in _bindSocket
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011 raise error.CannotListenError(self.interface, self.port, le)
Oct 21 12:35:23 maassrv maas-regiond[87949]: #011twisted.internet.error.CannotListenError: Couldn’t listen on :::5240: [Errno 97] Address family not supported by protocol.
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.396Z [pebble] POST /v1/services 136.733865ms 202
Oct 21 12:35:23 maassrv maas-regiond[87949]: provisioningserver.utils.services: [info] Beaconing process for enp0s25 started.
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.511Z [pebble] Service “http” starting: sh -c “exec systemd-cat -t maas-http $SNAP/bin/run-nginx”
Oct 21 12:35:23 maassrv maas-http[88362]: 2025/10/21 12:35:23 [emerg] 88362#88362: socket() [::]:5248 failed (97: Address family not supported by protocol)
Oct 21 12:35:23 maassrv maas.pebble[5435]: 2025-10-21T12:35:23.657Z [pebble] Change 5542 task (Start service “http”) failed: cannot start service: exited quickly with code 1
Oct 21 12:35:24 maassrv kernel: [100882.795991] tcpdump[88366]: segfault at 0 ip 00007f8ec406a20d sp 00007ffdb1d02570 error 4 in libc.so.6[7f8ec3f28000+188000]
Oct 21 12:35:24 maassrv kernel: [100882.796033] Code: 00 0f 85 a0 00 00 00 48 83 c4 38 89 d8 5b 41 5c 41 5d 41 5e 41 5f 5d c3 0f 1f 44 00 00 48 8b 05 f1 8b 09 00 8b 4d ac 64 89 08 <41> 0f b6 07 83 e8 2b a8 fd 0f 84 54 ff ff ff 49 8b 36 4c 89 ff e8
Oct 21 12:35:24 maassrv maas-regiond[87949]: provisioningserver.utils.services: [critical] Beaconing process for enp0s25 failed.
Oct 21 12:35:24 maassrv maas-regiond[87949]: #011Traceback (most recent call last):
Oct 21 12:35:24 maassrv maas-regiond[87949]: #011Failure: twisted.internet.error.ProcessTerminated: A process has ended with a probable error condition: process ended with exit code 3.
Oct 21 12:35:24 maassrv maas-log[88060]: maas.service_monitor: [error] Service ‘reverse_proxy’ failed to start: Pebble change 5542 failed with an error: cannot perform the following tasks:#012- Start service “http” (cannot start service: exited quickly with code 1)
Oct 21 12:35:41 maassrv maas.pebble[5435]: 2025-10-21T12:35:41.210Z [pebble] Service “rackd” starting: sh -c “exec systemd-cat -t maas-rackd $SNAP/bin/run-rackd”
Oct 21 12:35:41 maassrv kernel: [100900.383917] audit: type=1326 audit(1761050141.739:6528): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88382 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7f23b5a6025d code=0x50000
Oct 21 12:35:41 maassrv kernel: [100900.383927] audit: type=1326 audit(1761050141.739:6529): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.maas.pebble pid=88382 comm=“python3” exe=“/usr/bin/python3.12” sig=0 arch=c000003e syscall=425 compat=0 ip=0x7f23b5a6025d code=0x50000
Do you have ipv6 disabled on that host?
cat /proc/sys/net/ipv6/conf/all/disable_ipv6?
Yes I have it disabled since the beginning of OS config.
That’s the problem. Can you try again after enabling ipv6?
I will, no problem, but it worked for 2 weeks like that. I have deployed computers I have deployed the Juju controller as well and I was about to deploy Openstack services and in a morning I noticed UI was down
So I enabled back the IPv6 and it’s working again. Weird behavior though. Since I don’t need IPv6 why it is enforcing enabling it?
