I am new to MAAS. I installed it and I was able to deploy an OS to BIOS Based virtual machines, however when I tried to do the same on a UEFI Enabled virtual machine. (Secure Boot disabled) I get this error:
Fetching Netboot Image
Booting under MAAS direction…
error: Timeout reading
(http,IP_ADDRESS:5248)/images/ubuntu/amd64/ga-22.04/jammy/stable/boot-kernel.
error: you need to load the kernel first.
I am using MAAS 3.3.
Can you help me identify what could be causing this issue? Also does MAAS support Secure Boot?
