I’m trying to upgrade from 2.7 to 2.8. Unfortunately it is failing because the migrations take too long and exceed the timeout for the post-refresh hook of snapd.
Is there a way to fix this?
Thanks
snap refresh --channel=2.8 maas
error: cannot perform the following tasks:
- Run post-refresh hook of "maas" snap if present (run hook "post-refresh":
Operations to perform:
Apply all migrations: auth, contenttypes, maasserver, metadataserver, piston3, sessions, sites
Running migrations:
Applying maasserver.0203_interface_node_name_duplicates_delete... OK
Applying maasserver.0204_interface_node_name_unique_together... OK
Applying maasserver.0205_pod_nodes... OK
Applying maasserver.0206_remove_node_token... OK
Applying maasserver.0207_notification_dismissable... OK
Applying maasserver.0208_no_power_query_events...
<exceeded maximum runtime of 10m0s>
When re-attempting the upgrade, it also fails with the following error:
- Run post-refresh hook of "maas" snap if present (run hook "post-refresh": mv: cannot move '/var/snap/maas/13516/var/lib/maas' to '/var/snap/maas/common/maas': Directory not empty)
I’m not sure how to proceed. Is it safe to delete /var/snap/maas/common/maas?
hmm. i’m not sure how to tell you either. one way might be not to delete /var/snap/maas/common/maas, but to snap remove -- purge it and reinstall 2.8 in its place. i hesitate to recommend because i don’t know what you’d lose. let me bounce this back to the team and see if they have recommendations.
The initialization picked up the database migrations and completed them.
I had a backup of the database but did not have to use it.
Also I did not bother to try with 2.8. Jumped directly to 3.0.
