MAAS Site Manager Ready for Testing
Do you have more than one MAAS installation to take care of? Are you running your own image server to get those MAAS installations in sync and distribute custom images? Are you unsure how many machines are in a broken state in all your installations without logging into each and every one of them?
We are super excited to share that we have a solution for all those problems and a bunch of features on the roadmap to make managing multiple MAAS instances simple: MAAS Site Manager.
Key features :clipboard:
MAAS Site Manager delivers centralized visibility and control over your MAAS deployments with the following main features:
  • Site health & status overview: A central dashboard that contains an inventory of your sites and shows the high level machine availability and status across all your sites.
  • Geolocalization: Visualization of your sites on a map with extended meta-data.
  • Centralized image server: It acts as a powerful, central image hub for all your MAAS sites that can serve upstream images (e.g. from images.maas.io) including your custom images.
  • Easy enrollment: An intuitive and secure mechanism to enroll sites in MAAS Site Manager.
A sneak peek into the future :motorway:
We’re already working on features to bring even more simplicity and scale to your operations across all your sites:
  • Single Sign on: We are integrating OIDC-based SSO. Soon, you’ll gain secure, one-click access to multiple MAAS instances and MAAS Site Manager using a single username and password. (Coming to both, MAAS and MAAS Site Manager)
  • Coordinated MAAS sites configuration: MAAS Site Manager will become your single point of contact to deploy and manage diverse MAAS configurations across your entire environment.
MAAS Site Manager is ready to test
If you are ready to get started with the beta today you can grab and try the MAAS Site Manager Beta from charmhub. You can install it using terraform or follow our tutorial for manual deployment.
MAAS Site Manager Beta is compatible with the edge version of MAAS and will be fully supported from MAAS 3.8 onward.
Do you have any feedback? Leave your comments and suggestions in the forum. Your contribution is extremely valuable to help us shape the future of MAAS.
That sounds exciting. Will the OIDC-based SSO integration be available for the free version of MaaS?
yes, that’s the plan
Is there an alternative way for setting MAAS Site Manager for testing? May be setting up Site Manager from source code?
In general yes but I would not recommend it. The main reason why we recommend running the charms on Kubernetes is because it is not easy to connect Site Manager to Temporal and S3 storage.
But in theory it can run be from source and you could even use a hosted temporal instance. You can have a look at deployment/terraform/variables.tf to see what would need to be set up manually.
Is the ‘image server’ just a simplestreams server or something more sophisticated? We do customize our images, but can’t use simplestreams for it.
Sorry that we missed your comment. The image server is a a simplestreams server that can combine an upstream source (e.g. images.maas.io) with custom images and serves this combintion to all connected MAASes. You can also disable images that you don’t want to be forwarded from upstream.
