I’m running HA Mode with separate DB.
I created a new MAAS Region server installing from the 3.2 PPA Debian install.
Updated the config file to connect to the existing DB, but it fails with this.
I’m not sure if DB Table needs to be updated to match 3.2 or not.
/var/log/maas/regiond.log
2022-08-27 15:04:05 maasserver.start_up: [error] Database error during start-up
File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 84, in _execute
return self.cursor.execute(sql, params)
psycopg2.errors.UndefinedTable: relation "maasserver_nodeconfig" does not exist
LINE 1: ...last_sync" FROM "maasserver_node" LEFT OUTER JOIN "maasserve...
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/maasserver/start_up.py", line 65, in start_up
yield deferToDatabase(inner_start_up, master=master)
File "/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 250, in inContext
result = inContext.theWork()
File "/usr/lib/python3/dist-packages/twisted/python/threadpool.py", line 266, in <lambda>
File "/usr/lib/python3/dist-packages/twisted/python/context.py", line 122, in callWithContext
File "/usr/lib/python3/dist-packages/twisted/python/context.py", line 85, in callWithContext
return func(*args,**kw)
File "/usr/lib/python3/dist-packages/provisioningserver/utils/twisted.py", line 856, in callInContext
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/provisioningserver/utils/twisted.py", line 202, in wrapper
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 711, in call_with_connection
File "/usr/lib/python3/dist-packages/maasserver/utils/__init__.py", line 197, in call_with_lock
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 756, in call_within_transaction
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 559, in retrier
File "/usr/lib/python3.8/contextlib.py", line 75, in inner
return func(*args, **kwds)
File "/usr/lib/python3/dist-packages/maasserver/start_up.py", line 118, in inner_start_up
node = RegionController.objects.get_or_create_running_controller()
File "/usr/lib/python3/dist-packages/maasserver/models/node.py", line 748, in get_or_create_running_controller
node = self._find_or_create_running_controller()
File "/usr/lib/python3/dist-packages/maasserver/models/node.py", line 785, in _find_or_create_running_controller
node = self._find_running_node()
File "/usr/lib/python3/dist-packages/maasserver/models/node.py", line 807, in _find_running_node
return get_one(nodes.distinct())
File "/usr/lib/python3/dist-packages/maasserver/utils/orm.py", line 117, in get_one
retrieved_items = tuple(islice(items, 0, 2))
File "/usr/lib/python3/dist-packages/django/db/models/query.py", line 274, in __iter__
self._fetch_all()
File "/usr/lib/python3/dist-packages/django/db/models/query.py", line 1242, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File "/usr/lib/python3/dist-packages/django/db/models/query.py", line 55, in __iter__
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch, chunk_size=self.chunk_size)
File "/usr/lib/python3/dist-packages/django/db/models/sql/compiler.py", line 1140, in execute_sql
File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 67, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 76, in _execute_with_wrappers
return executor(sql, params, many, context)
File "/usr/lib/python3/dist-packages/django/db/utils.py", line 89, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
django.db.utils.ProgrammingError: relation "maasserver_nodeconfig" does not exist
