MAAS Rack Controller agent fails to connect to Temporal - "context deadline exceeded" causing PXE boot 502 errors
1
I have a MAAS 3.7.2 deployment with separate region and rack controllers. The rack controller (10.x.y.51) cannot connect to the Temporal service on the region controller (10.x.y.50), causing the maas-agent service to crash in a restart loop.
This prevents the httpproxy.sock from being created, which results in 502 errors when machines attempt PXE boot.
  - MAAS Version: 3.7.2-17972-g.35e297c4d (both)
  - Temporal Port: 5271 (gRPC frontend)
On Rack Controller
maas-agent Temporal connection failures:
maas-agent[46264]: ERR Temporal client error error="failed reaching server: context deadline exceeded while waiting   for connections to become ready"   maas.pebble[45464]: Service "agent" stopped unexpectedly with code 1   maas.pebble[45464]: Service "agent" on-failure action is "restart", waiting ~500ms before restart (backoff 1)
PXE boot 502 errors (machine 10.x.z.18 requesting bootx64.efi):
  maas-rackd[45499]: provisioningserver.rackdservices.tftp: [info] bootx64.efi requested by 10.x.z.18
  maas-http[45608]: [crit] connect() to unix:/run/snap.maas/httpproxy.sock failed (2: No such file or directory)
  maas-http[45612]:  127.0.0.1 - - "GET /images/bootx64.efi HTTP/1.1" 502 166
On region controller:
Temporal is running and healthy
  $ sudo netstat -tlnp | grep temporal
  tcp   0   0 127.0.0.1:9000   0.0.0.0:*   LISTEN   temporal-serv
  tcp6  0   0 :::5271          :::*        LISTEN   temporal-serv
  tcp6  0   0 :::5272          :::*        LISTEN   temporal-serv
  tcp6  0   0 :::5273          :::*        LISTEN   temporal-serv
I’ve tried to open firewall tcp/udp all ports between region controller and rack controller and the problem persisted.
1. The Temporal config shows rpcAddress: “localhost:7233” but the server listens on port 5271. Is the rack agent trying to connect to the wrong endpoint?
2. How does the rack controller learn the Temporal endpoint from the region? Is there a configuration file I should check/edit?
3. The Temporal frontend requires TLS client auth (requireClientAuth: true). Could certificate trust be preventing the connection?
4. What’s the correct way to configure the rack’s agent to connect to the region’s Temporal service?
More info:
 maas --version
  MAAS 3.7.2 (3.7.2-17972-g.35e297c4d)
Postgres 16
Any suggestion / guidance is greatly appreciated!
Hi there!
  1. The rack controller is not trying to connect to the wrong endpoint, it just connects over mTLS on TCP 5271.
  2. Temporal just runs on the region’s hostname and port 5271. I don’t think you need to edit any config files manually, since the region’s IP is part of MAAS’ config.
  3. It is likely
  4. If the issue is related to certificates, you can try clearing the certs from the rack (/var/snap/maas/current/certificates). Then, try restarting the rack (depending on if your installation is deb/snap). It should refetch the certificates from the region, and might resolve the certificate problem (though I suggest backing them up before clearing, in case you need to restore). Also ensure the region’s cluster-certificate secret exists. You can observe the regiond logs for this
Hello!
I’ll give it a try tomorrow morning and will get back to you, will also try that option with the certificates.
To be more transparent i’m using the snap version.
Hello again,
I’ve kept trying to make it work in the last days and keep going into different errors, the latest error is:
2026-07-08T10:30:43Z maas-http[5528]: 2026/07/08 10:30:43 [crit] 5528#5528: *427 connect() to unix:/run/snap.maas/httpproxy.sock failed (2: No such file or directory) while connecting to upstream, client: 127.0.0.1, server: , request: “G
ET /images/bootx64.efi HTTP/1.1”, upstream: “http://unix:/run/snap.maas/httpproxy.sock:/images/bootx64.efi”, host: “localhost:5248”
2026-07-08T10:30:43Z maas-http[5128]: 127.0.0.1 - - [08/Jul/2026:10:30:43 +0000] “GET /images/bootx64.efi HTTP/1.1” 502 166 “-” “-”
2026-07-08T10:30:49Z maas-rackd[5003]: provisioningserver.rackdservices.tftp: [info] bootx64.efi requested by 10.x.y.z
2026-07-08T10:30:49Z maas-rackd[5003]: provisioningserver.rackdservices.http: [info] /images/bootx64.efi requested by 127.0.0.1
2026-07-08T10:30:49Z maas-http[5529]: 2026/07/08 10:30:49 [crit] 5529#5529: *430 connect() to unix:/run/snap.maas/httpproxy.sock failed (2: No such file or directory) while connecting to upstream, client: 127.0.0.1, server: , request: “G
2026-07-08T10:30:49Z maas-http[5128]: 127.0.0.1 - - [08/Jul/2026:10:30:49 +0000] “GET /images/bootx64.efi HTTP/1.1” 502 166 “-” “-”
The socket is present, the port is open, the region controller and rack controller are on the same machine.
MAAS version is 3.7.2
