I use a specific VLAN to deploy servers with MaaS. This network is PXE and only serves to deploy. Once the server is installed, the PXE network is still configured but remains as the default network with a default gateway. I would like to know if there is a way with MaaS so that after the installation via PXE the default interface is another interface and add a static route for the PXE network to be able to reinstall the server at any time. Example VLAN222 PXE, VLAN 223 DATA at the time of installation VLAN 222 serves as default gateway but after installation VLAN 223 should replace and thus use another default gateway.
Thank you!
