The kickstarter is for the hardware, which includes the Raspberry PI, hat board for controlling the PC keyboard (USB) and PC display (HDMI) and power supply. The PIKVM connects to your pc USB and display HDMI ports so you can control the PC over your local network. The network port goes to you local network, or you can use WIFI. The ATX rj45 connector uses a special cable that plugs into your power control for your mother board. So the PIKVM connects to your local network (Ethernat or WIF) so you can get to your PC’s console over the local network using a web browser. It also has functionality where you can have an install ISO on a system on your local system and do a remote install of the OS. Does this answer your questions?
