i have 5 nodes in maas. 4 can been deployed… but for one i am getting an error : get() returned more than one Neighbour – it returned 2!
i have no idea how to go about fixing this or what the error means. Any help/suggestions is really appreciated.
Were enlisting and commissioning successful? It’s right?
Hi, @rocknrjiii,
I think we need more information.
We need to know the version and build (and packaging format) that you’re running. Here’s how to get that info:
If you’re using a snap, execute snap listmaas
at the command line, which will return some lines like this:
maas 3.0.0~beta2-9796-g.2182ab55f 13292 latest/edge canonical✓ -
Please add the output of that command to a comment on this post.
If you’re using a deb, execute apt list maas
at the command line, and enter whatever it returns into a comment to this post, as in the snap example above.
Next, you’ll need to specify which interface you’re using, and generally what command(s) you were attempting.
Being as concise and specific as you can, please explain a little more about what seemed to go wrong. Something’s returning a get()
error – what? CLI? A terminal? A pop up on the GUI?
Instead of the explanation above, you might try to create a step-by-step list of what you did to reproduce the problem.
Can you capture a few screenshots that give us a play-by-play? You can just upload them into your comment.
Logfiles might not have much in this case, but it’s worth looking at these files around the time you see the error:
On snap, they’re in:
If you’re using Debian packages, they’re somewhere else:
Ideally, you’d want to put these in a pastebin and link the pastebin location in your comment.
Thanks for this. We’ll very likely need this additional info to sort this.
