Hi
Sorry if miss categorised, I ran through the following guide below to install MAAS
Except it never gets the second IP address.
Inside the multipass VM I see running journactl -xe;
Jun 05 16:08:15 maas1 maas-test-db.postgres[22929]: 2022-06-05 15:08:15.777 UTC [22929] ERROR: could not serialize access due to concurrent update
Jun 05 16:08:15 maas1 maas-test-db.postgres[22929]: 2022-06-05 15:08:15.777 UTC [22929] STATEMENT: UPDATE "maasserver_service" SET "updated" = '2022-06-05T15:08:15.740846'::timestamp,>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22914]: 2022-06-05 15:08:15.777 UTC [22914] ERROR: could not serialize access due to concurrent update
Jun 05 16:08:15 maas1 maas-test-db.postgres[22914]: 2022-06-05 15:08:15.777 UTC [22914] STATEMENT: UPDATE "maasserver_service" SET "updated" = '2022-06-05T15:08:15.767121'::timestamp,>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.777 UTC [22927] ERROR: could not serialize access due to concurrent update
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.777 UTC [22927] STATEMENT: UPDATE "maasserver_service" SET "updated" = '2022-06-05T15:08:15.772412'::timestamp,>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22926]: 2022-06-05 15:08:15.780 UTC [22926] ERROR: could not serialize access due to concurrent delete
Jun 05 16:08:15 maas1 maas-test-db.postgres[22926]: 2022-06-05 15:08:15.780 UTC [22926] STATEMENT: DELETE FROM "maasserver_regionrackrpcconnection" WHERE "maasserver_regionrackrpcconn>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22926]: 2022-06-05 15:08:15.886 UTC [22926] ERROR: could not serialize access due to concurrent delete
Jun 05 16:08:15 maas1 maas-test-db.postgres[22926]: 2022-06-05 15:08:15.886 UTC [22926] STATEMENT: DELETE FROM "maasserver_regionrackrpcconnection" WHERE "maasserver_regionrackrpcconn>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.886 UTC [22927] ERROR: could not serialize access due to concurrent update
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.886 UTC [22927] STATEMENT: UPDATE "maasserver_service" SET "updated" = '2022-06-05T15:08:15.845143'::timestamp,>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22914]: 2022-06-05 15:08:15.912 UTC [22914] ERROR: could not serialize access due to concurrent update
Jun 05 16:08:15 maas1 maas-test-db.postgres[22914]: 2022-06-05 15:08:15.912 UTC [22914] STATEMENT: UPDATE "maasserver_service" SET "updated" = '2022-06-05T15:08:15.912118'::timestamp,>
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.966 UTC [22927] ERROR: could not serialize access due to concurrent delete
Jun 05 16:08:15 maas1 maas-test-db.postgres[22927]: 2022-06-05 15:08:15.966 UTC [22927] STATEMENT: DELETE FROM "maasserver_regionrackrpcconnection" WHERE "maasserver_regionrackrpcconn>
Jun 05 16:08:16 maas1 systemd[1]: snap.maas.supervisor.service: Succeeded.
-- Subject: Unit succeeded
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- The unit snap.maas.supervisor.service has successfully entered the 'dead' state.
Jun 05 16:08:16 maas1 systemd[1]: Stopped Service for snap application maas.supervisor.
-- Subject: A stop job for unit snap.maas.supervisor.service has finished
Please let me know if you need anymore info!
