maas+lxd cluster pxe over fan network
So I have MAAS setup with an LXD cluster. The cluster has servers on the MAAS node as well as 4 other nodes.
Everything works well on the LXD side, but I want to be able to deploy a vm via MAAS.
I did configure the fan network to have dhcp so I can do the pxeboot, but when the node tries to boot, it is never able to get any image, timing out all attempts and dropping to the ‘shell>’ prompt.
It feels so close. Is this something that is possible? I had unclustered working fine, just wanted to try the clustering out as well.
Running under Ubuntu 24.04 with lxd 6.5-22da890/maas 3.5.8-16381-g.d7e999261
Brian Andrus
Probably LXD is providing DHCP on that network. Check the LXD networks to ensure this is actually the case
That seems to be the conundrum. Looks like if I use a lxd fan bridge, I cannot disable the dhcp. Not finding how to create one in MAAS. I suppose I could look into OVN and getting things set, but that seems a bit more complicated than I am ready for.
At least I know I can have separate vm hosts in MAAS and it works. Clustering them was just a rabbit hole I wanted to explore a little. C’est la vie.
