Pinpoint issues with four types of log files:
- Firewall logs
- Web server logs
- MAAS log files
- System log files
You can also account for user activities with audit logs.
See How to use logging for usage instructions.
Firewall logs
Ubuntu’s UncomplicatedFirewall (UFW) serves as a front-end for iptables. To secure your MAAS setup, regularly review logs located in /var/log/ufw*.
Find red flags in UFW and iptables logs by looking for key patterns:
- Be wary of traffic probing unused ports, which may indicate an active port scanner:
Cross-reference unusual port numbers against databases of known hacker tools.
Look for repeated, failed access attempts from the same domain, IP, or subnet:
- Examine repeated, errant messages from within your network, which may indicate a Trojan horse:.
Web server logs
Use a log analysis tool, or inspect raw logs stored in paths like /var/log/httpd/ or /var/log/apache2, looking for:
- Multiple, rapid-fire requests
- Multiple failed login attempts
- Requests for non-existent pages
- Signs of SQL injection and Web shell attempts
MAAS logs
| Pkg Fmt | Look for failed logins in… |
| Snap | /var/snap/maas/common/log/regiond.log |
| Packages | /var/log/maas/regiond.log |
For example, a legitimate login request might resemble:
2020-03-31 21:17:56 regiond: [info] 10.132.172.1 GET /MAAS/accounts/login/ HTTP/1.1 --> 200 OK
System logs
Systemd log commands (MAAS 3.5 and Newer)
| Component | Snap Command | Debian Command |
| Regiond | journalctl -u snap.maas.pebble -t maas-regiond |
journalctl -u maas-regiond |
| Rackd | journalctl -u snap.maas.pebble -t maas-rackd |
journalctl -u maas-rackd |
| API Server | journalctl -u snap.maas.pebble -t maas-apiserver |
journalctl -u maas-apiserver |
| Proxy (squid) | journalctl -u snap.maas.pebble -t maas-proxy |
journalctl -u maas-proxy |
| NTP (chrony) | journalctl -u snap.maas.pebble -t chronyd |
journalctl -u chrony |
Log file locations (Before MAAS 3.5)
| Component | Snap Location | Debian Location |
| Regiond | /var/snap/maas/common/log/regiond.log |
| Rackd | /var/snap/maas/common/log/rackd.log |
/var/log/maas/rackd.log |
| maas.log | /var/snap/maas/common/log/maas.log |
/var/log/maas/maas.log |
Audit logs
Read the following information from MAAS audit logs.
| Event type | Endpoint | Req’d params | Audited user event |
| AUTHORISATION | API | None | “Created token.” |
| AUTHORISATION | API | None | “Deleted token.” |
| NODE | API | system_id |
“Created bcache.” |
“Deleted bcache.” |
“Updated bcache.” |
“Created bcache cache set.” |
“Deleted bcache cache set.” |
“Updated bcache cache set.” |
| API | None | “Deleted script script.name.” |
| API | None | “Deleted DHCP snippet dhcp_snippet.name.” |
| API | None | “Deleted package repository package_repository.name.” |
| SETTINGS | API | None | “Reverted script script.name to revision revision_number.” |
| API | None | “Added tag tag to script script.name.” |
| API | None | “Removed tag tag from script script.name.” |
| API | None | “Imported SSH keys.” | |
| API | None | “Deleted SSH key id=id.” |
| API | None | “Tag name {action}.” |
| TAG | API | None | “Tag tag.name deleted.” |
| API | None | “Tag tag.name created.” |
| API | None | “Created SSH key.” | |
| API | None | “Deleted SSH key.” | |
| AUTHORISATION | None | “Created SSL key.” | |
| None | “Updated dhcp_snippet.name.” |
| None | “Updated package_repository.name.” |
| SETTINGS | None | “Saved script script.name.” |
| SETTINGS | CLI | None | “Updated configuration setting key.” |
